Does anyone know the name of this TO30 Z129 throttle part?
   / Does anyone know the name of this TO30 Z129 throttle part? #1
FergFan
Middleburg, FL
1953 Ferguson TO30 Z129
Looking for part #12
I'm unable to adjust my throttle. The "pencil like arm piece":confused: that connects to the throttle adjuster above the steering wheel has completely rusted out on one end. Meaning I can push the throttle one way, but can't pull it back the other (won't stay connected) I apologize for the terminology...new to this tractor
   / Does anyone know the name of this TO30 Z129 throttle part? #2
My suggestion to you is goto: AGCO Parts Books Book number 693041
Find the link that says "browse books" Look under Ferguson. Drop to almost the bottom for a listing
TO30/TO20/TE20/TEA20 TRACTOR
Look for the throttle control section. Those pages and parts list with description are fully printable. Be advised if you don't have Microsoft Silverlight installed you may be able to see the graphic pictures. I have Silverlight, but I'm also using Google chrome and view with no problem. I found a picture similar to yours that why I wanted to point you in that direction so you may verify if it's the same thing.
If this is your control, then search the net for an Agco dealer in your immediate area. By having the part number at hand will be a big help either talking to a dealer or a salvage yard to find your part. Good luck. -robert
   / Does anyone know the name of this TO30 Z129 throttle part? #3
Per the parts manual #12 is part number 181 672 M1 Stud(1/4" x 3-1/16").
That AGCO book was a tremendous find..thank you thank you thank you
   / Does anyone know the name of this TO30 Z129 throttle part? #5
Yes it's very helpful, so when you call to order you don't call it a whatchamacallit.. :)
   / Does anyone know the name of this TO30 Z129 throttle part? #6
You might want to think about replacing parts 13 and 14 too. THey are a wear item also. JD has a similar part in their throttle linkage, it is an assembly though.
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52128)
2016 Ford F550 4x4...
UNUSED FUTURE HYD HOSE BUNDLE (A51244)
UNUSED FUTURE HYD...
2007 Volvo VNL Truck Tractor (A52128)
2007 Volvo VNL...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2018 Ram 1500 Crew Cab 4x4 Pickup Truck (A51568)
2018 Ram 1500 Crew...
