Does anyone know the brand of this finish mower?
   / Does anyone know the brand of this finish mower? #1
Tigerepair
Yanmar ym140
So I tried to take the blades off not knowing they were right hand thread. I broke BOTH can anyone Id this FInish mower? Thissunhere. IMG_20200815_124231581.jpgIMG_20200815_124225698.jpg
   / Does anyone know the brand of this finish mower? #2
Don't know but it your going to match it on computor images don't go by the color black .I have seen Northtrac/Yammar/ Titan/Woods/ finish mowers that came in black . Of course some of them didnt make them but just sold them with there logo .
That helped a lot but still havent found it. I will upload the cover for the shape
   / Does anyone know the brand of this finish mower? #4
Why do you need to know the manufacturer?
The spindles are generic, County Line/King Kutter {TSC junk but serviceable}
Just drill out the broken spindle bolts {Bearings too, if needed} or replace the entire spindle assembly.
If the gear box is grumbling, replace it, as well.
I wish it was as simple as going down to buy a spindle (there are no spindles at my tsc not 1 i can go hold in hand before buying a ton online though) but as you may know there are some 20-50 spindle sizes out there... the shaft on one is sloppy with the pulley fit. on top and its making a ton of heat so i need a shaft.
I want to know the brand so i can buy a spindle that will fit or order a shaft that will fit or fit correct pulley on top. I will take it off today post come more pix perhaps they are simple generic spindles i can easily match.
Also I meant I broke the blade bolt not the mounting bolts . Thanks everyone for your replies so far. I BORROWED THIS FROM NEXT NEXT NEXT DOOR NEIGHBOR is the worst part
Does anyone recognize this finish mower please!
   / Does anyone know the brand of this finish mower? #8
You mentioned removing the spindle and taking pictures but I don't see any of those. As already stated, there is zero need to ID the finish mower. Take the spindle off, measure appropriately, and buy a replacement. Not to be rude, but if you had done this a month ago when it was first suggested, this would have been over and done with long ago.
   / Does anyone know the brand of this finish mower? #9
Absolutely! Buy a replacement shoulder bolt from a farm/landscape supplier. Get the numbers off the bearings for replacements and rebuild the entire spindle back BETTER than when you got it.
I’ve rebuild a few of mine, over the years pre-lubed to airline spec grease, and SS covers. They’ll never wear out with homeowner use.
Metal Cabinet With Caster Wheels (A53425)
Metal Cabinet With...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A55745)
2018 DRAGON 150...
(6) ROLLS OF MISC LINOLEUM (A54757)
(6) ROLLS OF MISC...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
2025 Raytree RMBD50 Hydraulic 50in Drum Mulcher Skid Steer Attachment (A53425)
2025 Raytree...
2019 KENWORTH T880 HYDROVAC (A55745)
2019 KENWORTH T880...
