Does anyone have a 4 in 1 bucket?
   / Does anyone have a 4 in 1 bucket? #1
construction freak
texas
kubota mx5100
I was looking into buying a tool to clear 15 acres at not go broke buying it and I would like feedback on how it operates or if i need to look into something else so please help me out.
   / Does anyone have a 4 in 1 bucket? #2
Knapper on the Kioti forum has a 4 in 1 bucket on both his Kioti NX6010 and his John Deere 4720.
   / Does anyone have a 4 in 1 bucket? #4
Haven't used one on a smaller tractor, but they are great on skip loaders. I've used them for picking up rocks, dirt, pulling stamps and bushes, stuff I couldn't do with a regular bucket. However, more information is needed to know whether or not it is a wise investment, if that is what you are asking.
   / Does anyone have a 4 in 1 bucket? #5
I used one on an old payloader (Hough H-70) many years ago. It was very effective for ripping out trees. I would open the bucket up and put it flat against the tree. Then I would tilt it down, snapping off the top. Next, I lowered the bucket down to the stump, close to grip it, then lift and rip out the whole works, roots and all. The closed cab with metal mesh over the glass was a necessity there, and trees up to a foot or so diameter were no problem at all. The 4-1 was also nice for cleanup work and I got to where I could leave less than a shovel full of material (dirt, rocks, etc,) by clamping the bucket for the last load. Opened up and flat against the ground, the 4-1 bucket made a nice box for back-dragging and leveling. I don't think one would be really effective on a CUT, but on a larger cabbed tractor it would work ok.
Here is a pic of me and my rig and a pic of what I am trying to clear. wolc 123 that is exactly how i want to use it. Have beeen studying up on buckets and i am leaning towards the Bradco 72 Compact Tractor 4-in-1 Bucket.Is there a better atachment or way to clar this ?
   / Does anyone have a 4 in 1 bucket? #7
Easiest to me would be to hire a Dozer man to clear it.
Cheapest to me would be buy a used Dozer and clear it yourself. Then resell for probably close to what you have in it.
Doing it yourself with your tractor will take a long long time. More than likely you'll have a bunch in repairs too.
Brett
   / Does anyone have a 4 in 1 bucket? #8
My rotary cutter would make all that vanish in no time. Buy a Woods BB720X.
   / Does anyone have a 4 in 1 bucket? #9
The problem with a 4-in-1 bucket on a CUT like the MX you have is that you're not gonna be able to close the bucket on them and pull them up if they are of any size at all unless they have a very shallow weak root structure. Notice that wolc123 said he did that with a payloader, which is a bird of a different feather.
And the problem with using a brush hog to do it is that you're going to leave all those little trunks sticking up about 2 - 4" above the ground. While a brush hog with dull blades will pulverize them enough that they don't become punji sticks that will stick through a tire, you'll be tripping over them every time you walk through the area.
If it was me, I'd rent an excavator or I'd hire a dozer to clear it.
   / Does anyone have a 4 in 1 bucket? #10
We have a prairie restoration project in progress. To prepare the land we hired a bulldozer guy four years ago to remove more than hundred scattered large trees and bunch of small trees from about 30 acres. He showed up with D5 CAT with 5 way blade and it took him about 9 hours to do the job. All trees removed, pushed on piles and holes smoothed out. Paid $1000. He didn't charge us for transportation because they were doing terracing and pond near by.
Unless the job you need to do is small it could be fun to do with your tractor. Otherwise I would hire a bulldozer with a skilled operator or guy with FECON land clearing machine.
Fecon - Tough Forestry Equipment Made in the USA
2015 KUBOTA M9960 LOT NUMBER 121 (A53084)
2015 KUBOTA M9960...
2025 CFG Industrial MH12RX (A50123)
2025 CFG...
1995 VOLVO BM A25C 6X6 OFF ROAD WATER TRUCK (A51246)
1995 VOLVO BM A25C...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2015 Suzuki Kingquad ATV (A51694)
2015 Suzuki...
