Mowing DOES ANYONE FINISH MOW WITH A 35 or 40 HP TRACTOR??
   / DOES ANYONE FINISH MOW WITH A 35 or 40 HP TRACTOR?? #11
My tractor weighs about 5500 lbs.
Tractordata said your boomer 35 only weighs 2900 pounds. tractor only.
   / DOES ANYONE FINISH MOW WITH A 35 or 40 HP TRACTOR?? #12
It's more about soil, moisture content and tires than other things. I live in clay soil that is like a wet sponge in the spring and blacktop in the hot and dry summer. I have mowed with a 30HP, 1,700lb B7800 Kubota pulling a 7 ft Woods mower and I have also mowed with a 90 HP, 9500 lb Deere pulling the same mower. Either one can do serious--or zero--damage depending on conditions.
Stay off the ground when it's wet or damp. Period. Wet will rut to varying degrees so stay off. Better yet, anticipate the rain and mow in advance or wait it out and deal with it. Mow at 3 1/2" and you wont have to rake anything, ever and can wait until it's dry.
No circling turns around trees in the Spring and almost no turns unless wide and sweeping. Industrial tires--or maybe turf.
Now, when it's hot and dry in July. August and maybe September, I saddle up the big Deere and have my way with the lawn. No real sharp turns, of course, but no ruts, no damage and no nothing. It just works like a champ. In the wet Spring, a bicycle will do damage while in the dry summer I could probably do donuts with my truck and not have a problem.
So, more than the size of the tractor it's how you use it and what kind of tires are on it.
   / DOES ANYONE FINISH MOW WITH A 35 or 40 HP TRACTOR?? #13
My L3200 is 32hp & about 3,500 fully loaded + mower. I have R4 tires & get minimal if any marking on my field unless the ground is wet or damp. Tight turns scuff a bit, but thats it.
   / DOES ANYONE FINISH MOW WITH A 35 or 40 HP TRACTOR?? #14
I finish mow with a 17 hp tractor. Unless you mow when it is extremely wet there is no damage. I'd like to trade this thing in for a newer B with power steering.
1974 John Deere 6030 Tractor (A56435)
1974 John Deere...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
1994 CAT 322L (A55272)
Toro GreensMaster 1600 Walk-Behind Reel Mower (A55787)
Toro GreensMaster...
Hays LT1 Tender (A56435)
Hays LT1 Tender...
New Land Honor Heavy Duty Plate Compactor (A59000)
New Land Honor...
