Traction Does anyone find the front of the 3039 LS tractor light?
   / Does anyone find the front of the 3039 LS tractor light? #11
Hello Bob77064 I looked on the LS website and a few others that sold LS parts and none of them listed weights or weight bracket for the LS R3039H.
Are you talking about a LS dealer? Does anyone have a picture of the mounting frame. I have a friend who is a good welder/fabricator and I am sure he could come up with something.
Thanks Bob
George
George,
Do you have your operator manual? If so check the Lubrication and maintenance page. Mine shows a pic of the tractor with weights hanging on the front.
   / Does anyone find the front of the 3039 LS tractor light? #12
George, yes it was the LS dealer that told me that and it was an LS part.
   / Does anyone find the front of the 3039 LS tractor light? #13
I would start with a cheaper fix, fluid fill the front tires. that will add additional weight to the front end.
   / Does anyone find the front of the 3039 LS tractor light? #14
had the same problem with mine until i put chains the front, do you have the rear tires filled? the backhoe will be a problem plowing, i have a counter weight built and it sucks to plow with it on, if your doing a lot of gravel or dirt areas you can put a piece of pipe on the cutting edge to help the digging in, also a brand new cutting edge on a blade is a ***** to use until it gets broken in you will do more "landscaping" than plowing lol
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
2842 (A54756)
2842 (A54756)
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
2016 Toro Workman HDX-D Utility Cart (A55787)
2016 Toro Workman...
