Not without modifying it significantly.
However, I think the longer ladder type backhoe frame (8a) is easier on the tractor than the shorter one intended for 4x10 series. The longer frame distributes the loading better. There is a frame reinforcement pan they'd like to sell you with the newer one, too. It goes from rear end up to front subframe, but it looks more like $500+ skid plate to me. Not much good in torsion. There have been plenty of tractors broken in two with the shorter, newer backhoes.
I've got a 4410 with an 8a on it. The ladder frame was extended about 20 in and I fabricated tractor reinforcements with hook/latch plates to engage cross bar on this extended ladder frame. The front engagement area is below bellhousing. Reinforcements are bolted to front engine subframe, bellhousing below loader mounts points, and back beneath trans.
At the rear, I added 3/4" plate drop ears to the bottom of ROPS/sway control plate clamped on axle. I then used double shear pockets at the outside of backhoe frame to pin to drop ears.
To install you back tractor over subframe. Front bar engages in hook plates. Hook up hoses and lift rear of backhoe frame w/ stabilizers and engage rear pins.
I do not recommend using the three point connections at the rear end as opposed to drop ears or something else. That rear axle housing is aluminum and you don't want to break those off. That has apparently been a problem for some, too.
I'll post some pictures if you'd like.
