Does AL1684E Frontier snow plow fit a 3320 tractor?
   / Does AL1684E Frontier snow plow fit a 3320 tractor? #1
stanmeyer
Hello, I own a 3320 Deere tractor and need a snow plow attachment. Found a used Frontier model number AL1684E for sale nearby but cannot find anywhere on the internet if this plow will fit or work properly on the 3320. The present owner says they used it on a 400 series but cannot confirm whether it fits the 3320 or 300 series. Also, can hydraulics be added to this plow? Any insight would be greatly appreciated. Thank you.
   / Does AL1684E Frontier snow plow fit a 3320 tractor? #2
If it was mounted on a 400 series loader then it should fit a 300 series on your 3320 tractor. All attachments are compatible from the 200, 300, 400 series loaders.
John
   / Does AL1684E Frontier snow plow fit a 3320 tractor? #3
Welcome to TBN:D
It will fit just fine, and hydraulic angling cylinders can be added if it does not already have them. you will need an extra circuit like the 3rd SCV option to use hydraulic angling.
   / Does AL1684E Frontier snow plow fit a 3320 tractor? #4
Yes, this plow will work. The hydraulics are really nice, too. Get them, you'll need them. This plow is a big 'un for a 3000 series tractor, though. You might find your front end moving back and forth quite a lot. It is VERY heavy and cumbersome. I did not particularly like mine, but to each his own. Snowplowing does not require heavy plows. I found my Gator, with a 100# 72" Eagle plow could move snow much better than my then 3720 with this plow. Since you are getting a good deal on it, I would buy it, but otherwise I would have passed on this purchase unless you plan on doing some grading with it also.
John M
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
2012 PETERBILT 365(INOPERABLE) (A52472)
2012 PETERBILT...
2021 FORD TRANSIT 250 CARGO VAN (A52576)
2021 FORD TRANSIT...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
