Does AL1684E Frontier snow plow fit a 3320 tractor?
   / Does AL1684E Frontier snow plow fit a 3320 tractor? #1
stanmeyer
Hello, I own a 3320 Deere tractor and need a snow plow attachment. Found a used Frontier model number AL1684E for sale nearby but cannot find anywhere on the internet if this plow will fit or work properly on the 3320. The present owner says they used it on a 400 series but cannot confirm whether it fits the 3320 or 300 series. Also, can hydraulics be added to this plow? Any insight would be greatly appreciated. Thank you.
   / Does AL1684E Frontier snow plow fit a 3320 tractor? #2
If it was mounted on a 400 series loader then it should fit a 300 series on your 3320 tractor. All attachments are compatible from the 200, 300, 400 series loaders.
John
   / Does AL1684E Frontier snow plow fit a 3320 tractor? #3
Welcome to TBN:D
It will fit just fine, and hydraulic angling cylinders can be added if it does not already have them. you will need an extra circuit like the 3rd SCV option to use hydraulic angling.
   / Does AL1684E Frontier snow plow fit a 3320 tractor? #4
Yes, this plow will work. The hydraulics are really nice, too. Get them, you'll need them. This plow is a big 'un for a 3000 series tractor, though. You might find your front end moving back and forth quite a lot. It is VERY heavy and cumbersome. I did not particularly like mine, but to each his own. Snowplowing does not require heavy plows. I found my Gator, with a 100# 72" Eagle plow could move snow much better than my then 3720 with this plow. Since you are getting a good deal on it, I would buy it, but otherwise I would have passed on this purchase unless you plan on doing some grading with it also.
John M
John Deere Lift Arms (A50121)
John Deere Lift...
2007 Chevrolet WA4500 Box Truck (A50323)
2007 Chevrolet...
Generac 5000Watt Heavy Duty Diesel Generator (A51691)
Generac 5000Watt...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A52577)
2016 WESTERN STAR...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
