plowhog
Elite Member
- Joined
- Dec 8, 2015
- Messages
- 3,394
- Location
- North. NV, North. CA
- Tractor
- Massey 1710 / 1758, Ventrac 4500Y / TD9
I'm building a new residence, about 5,600 sq ft total. The garage is on one side, great room/laundry room about the center, and bedrooms and master on the other side.
My architect planned an on-demand water heater in the garage, mainly servicing the kitchen and a bath in that area. And a second on-demand in the laundry, to service the bedroom wing and master suite.
My plumber wants to relocate the laundry on-demand heater to the garage, so the two on-demand heaters are together. Then plumb them as a master/slave unit, where only one fires if needed, or both fire if there is a lot of demand. I think he also wants to do this when a lot of temperature rise is needed, such as when the incoming cold water is ... cold ... during the winter. I am on a well.
I pointed to the plans which would not be a looooong run from the on-demand heater to the bedroom wing and master bathroom. Almost as far away as you could possibly get. He said no problem: add a recirculating pump. This would constantly recirculate the water through the piping under the house, keeping everything hot while waiting to be used. But also burning electricity and $$$ even while we are sleeping or are away from the house. The underside plumbing is in a crawl space, is PEX, and is insulated.
I asked if constantly running a recirculating pump defeats the energy-saving approach for on demand units? And there are apparently some on-demand units that are not compatible with such a pump?
My plumber says this is the best way to go. I'm not so sure? Do you have any experience or ideas that could help? I'm waiting to get the model numbers of the on-demand heaters so I can examine them in more detail.
