Does a DK55 have a front pto option?
   / Does a DK55 have a front pto option? #1
sqdqo
Marquette Michigan
Massey Ferguson 492 w/Quicke Q750 loader
I was reading through the DK55 specifications on Kioti's web site and saw where Kioti states "front pto speed same as engine speed ". Does the DK55 have a front pto option? If so can you run a front mount snow blower with it?
   / Does a DK55 have a front pto option? #2
I think you can connect to the front end of the crankshaft but some sort of clutch and gear reduction would be needed. Maybe there are kits for this; I don't know.
   / Does a DK55 have a front pto option? #3
Most of your front driven items [snowblower] run at higher [2100 rpm] speeds. So not reducers required. I was going to use mine to run a hydraulic pump but not enough ground clearance to leave the pump on. CJ
   / Does a DK55 have a front pto option? #4
maybe they were talking about the middle PTO, never heard of a "front" PTO like all the big tractors
   / Does a DK55 have a front pto option? #5
The mid pto faces forward and can run a front mounted blower. Its a $200 option that the dealer can order for you. Install it next time you change your hydraulic fluid. It does hang down about the same as the backhoe bracket.
2008 JACK COUNTY  130BBL VACUUM TRAILER (A52472)
2008 JACK COUNTY...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A52748)
Gooseneck...
Rogers 4th Axle (A51572)
Rogers 4th Axle...
New Land Hero Mini Excavator (A53002)
New Land Hero Mini...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
