Does 7 IRON 72" MMM fit a JD 2520?
   / Does 7 IRON 72" MMM fit a JD 2520? #1
Deadman
WI
John Deere 2520, X475
I'm looking to find a nice 72 inch MMM for my JD 2520. Can I put a 7 IRON 72 inch MMM under it? Or can I only run the lighter version of the 72 inch MMM?
I found a nice 7 IRON MMM and would buy it if fits my 2520, but if it won't fit I will look for a lighter 72. If indeed I do need the lighter version of the 72 inch MMM, is there a specific name or model number for the MMM?
Thanks in advance! :thumbsup:
   / Does 7 IRON 72" MMM fit a JD 2520? #2
Good luck in your search. I would kill or die to have a 7-Iron deck for my 2520 - a 60"-62" would suffice.
   / Does 7 IRON 72" MMM fit a JD 2520? #3
I tried finding the answers on the John Deere website but that data is "currently unavailable" for some reason. I have a 72" 7-Iron MMM on my 3720 tractor and it is a great mower. I suspect at the very least you would need to buy specific hangers and hydraulics to make it work on your 2520 if it is even possible. So, I'd investigate the additional parts aspect with your JD dealer prior to buying and he can also answer the question if that mower will work on your tractor. The attaching parts can sometimes sway your decision as those parts are usually costly and add to the price of the mower.
Dealer said they never listed anything for a 7 iron on a 2520, so I suspect its not worth the trouble. If I could buy the attachment kit and bolt it on, I would do it in a heartbeat. Guess I'll find a lighter duty 72! :(
   / Does 7 IRON 72" MMM fit a JD 2520? #5
The lighter duty deck is still heavy duty.
   / Does 7 IRON 72" MMM fit a JD 2520? #6
lookin to put one on my 2720 getting quotes just under 4000 wish I could find a used one
2020 Toro 6000 Series 60in Zero Turn Commercial Mower (A50322)
2020 Toro 6000...
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
Presto Electric Pallet Jack (A47384)
Presto Electric...
2012 Freightliner M2 106 Ambulance (A50323)
2012 Freightliner...
Lot (2) HD 10' Pipe Gates (A50515)
Lot (2) HD 10'...
