Dodge Trailer Wiring Question
   / Dodge Trailer Wiring Question #1
timswi
Elite Member
Beaver County Pa
Kubota BX23 TLB, Kubota RTV1100, Kubota Z724 & Polaris RZR 900 Trail
My neighbor has a 2010 2500 Dodge with integrated brake controller and 7 pin trailer plug. There is no auxiliary power or break away 12v power at in the plug, everything else works. There are 2 30A fuses under the hood J01 and J02 if I remember correctly. Main question, are Dodge 7 pins fully wired or do wires need to be pulled? My GMC's always came factory hot. He bought a power jack for the trailer and the directions mentioned that some Fords don't have this power in the plug so use the parking light slot..Dodge wasn't mentioned.
Some trucks left the wires spooled up underneath, even with a 9 inch lift kit, we didn't see anything.
Anyone know for sure if these are factory wired for dedicated 12v at the 7pin before we tear into this? Thanks.
   / Dodge Trailer Wiring Question #2
My GM has the factory integated brake controller. It came pre wired to the plug but was not connected under the hood in the fuse block. Just had to connect the wire and plug in a fuse. A friends F150 was set up the same. Dodge is probably similar.
Check the fuse block under the hood. Trailer power fuse location should be noted which fuse it is. Then check around or under the fuse box for that wire that needs to be hooked up.
   / Dodge Trailer Wiring Question #3
My 2011 1500 with the factory brake controller has 12v at the 7 pin connector but I haven't checked to see if it is 100% hot or just hot when the key is on. Seem like I remember that some where key on hot only.
   / Dodge Trailer Wiring Question #4
My neighbor has a 2010 2500 Dodge with integrated brake controller and 7 pin trailer plug. There is no auxiliary power or break away 12v power at in the plug, everything else works. There are 2 30A fuses under the hood J01 and J02 if I remember correctly. Main question, are Dodge 7 pins fully wired or do wires need to be pulled? My GMC's always came factory hot. He bought a power jack for the trailer and the directions mentioned that some Fords don't have this power in the plug so use the parking light slot..Dodge wasn't mentioned. Some trucks left the wires spooled up underneath, even with a 9 inch lift kit, we didn't see anything. Anyone know for sure if these are factory wired for dedicated 12v at the 7pin before we tear into this? Thanks.
The GM's leave a wire loose under the hood that must be connected and a Maxi Fuse that needs installed. Not a big deal and the good dealers do it before delivery.
The Fords need a relay installed. It comes with the truck and is usually in the center console or glove box.
The Dodges are a crap shoot. It can vary year to year. Best thing to do is go to R&P Carriages website and check out the HELP section.
Chris
Ok, I'm a bonehead ...The 30a's looked good. After a continuity test, one was bad...Now we have live 12v on the 1 O'clock slot..The center pin is still dead, ignition or not. Must be a relay or something.
   / Dodge Trailer Wiring Question #6
The center pin is tied to reverse in my 98. Dodge may have kept it the same, put the truck in reverse with ignition on and see if it becomes hot.
It may, I'll check that...Thanks. Looks like that is a user choice slot. None of our trailers have reverse lights, so no point in digging for it I guess.
Thanks for all of the help everyone.
   / Dodge Trailer Wiring Question #8
On everything I use with 7 slot connector the center pin is wired up for reverse/backup lights..I added in xtra rear facing lights to my 18ft trailer so I could see backing up in the dark.
   / Dodge Trailer Wiring Question #9
That's the standard. We use them on Disc Brakes to control the reverse solenoid lockout.
Chris
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
UNUSED CHERY INDUSTRIAL 9.5' WORKBENCH (A51248)
UNUSED CHERY...
250 GALLON FUEL TANK (A51247)
250 GALLON FUEL...
1999 Volvo VN Truck, VIN # 4VA7BBJF9XN770848 (A51572)
1999 Volvo VN...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
AMADAS 2100 LOT NUMBER 255 (A53084)
AMADAS 2100 LOT...
