Document preparation fees--RIPOFF
/ Document preparation fees--RIPOFF #121
I too used to think doc fees were as big a rip-off as the service charges at the dealership. Then I had my wife's vehicle in for some service ...... service writer called me to say it needed a new muffler bearing. I said "Whaaaaa ?????" Rushed right down there, he takes me out back to show me.
Now that I see they are honest, I don't second guess them anymore.
It is a known fact that low taillight fluid will contribute to early demise of the muffler bearing.
/ Document preparation fees--RIPOFF #122
People might laugh. But My recient used car apparently had never had the air changed.Shortly after getting it home the tire light came on, I equalized all the tires and the light still remained on.
The next day i pulled all four valves stems. and then re inflated to 35 lobs and then the light went out..Apparently there is a difference in the air.Perhaps it needed 'country' air and not the 'city' air...:laughing::laughing:
/ Document preparation fees--RIPOFF #124
Thats weird, the last muffler I put on a car was blown open, and all the muffler bearings were gone. Must have been burned up already or fell out. I also change the air in my tires, the air in your tires can get a lot of moisture in them to the point it will rain inside your tires.
/ Document preparation fees--RIPOFF #125
And dangerous loss of traction/ hydroplaning.
/ Document preparation fees--RIPOFF #126
I had snow in the inside of my tires....guess cause I'm in north Idaho. It snows everywheres up here. Now i need to find a snowblower that will fit inside of my tires to keep the rims clear. I had a bearing go out in my spark plug that caused a failure of the ionic combustion chamber next to the frequency generator....at least i think thats what the mechanic told my wife :laughing: :D
OP here. this thread is so far off topic by now it is inane, and the laughs you are providing me make driving an 11, oops, 12 year old truck almost worthwhile again.
Keep it going !! :thumbsup:
WARNING, WARNING.....did you ALSO change the air in the spare tire? VERY IMPORTANT, otherwise, the city air in that spare will gradually migrate to the other four tires and the problem will recur.
Those of you who own a vehicle with no spare tire may ignore this important safety tip.
/ Document preparation fees--RIPOFF #129
Yeiks... i never thought about that. If i add summer air to the spare, maybe i can let it out in the winter and melt some snow off of my property.
/ Document preparation fees--RIPOFF #130
HEHE..Just for the heck of it, lets see how far off of the original post we can take this
/ Document preparation fees--RIPOFF #131
If you ever have to change the tires on a 1997 Dodge 1500 4x4, remember that they take a 3/4" socket, NOT a 19mm socket. A 19mm socket is a different size and it is enough bigger that you can snap it if you reef on a 3/4" lug nug with one.
Or so I was told by a "mechanic" at Monroe when I took my wife's truck in to have them loosen the lugnuts after I snapped a socket bouncing on a 4' cheater bar (250#+ of me bouncing on a 4' cheater bar over a breaker bar wouldn't budge the lugnut and he tells me that the reason the nut wouldn't come off is because I was using a 19mm socket rather than a 3/4" one :eek:.
For those who dont know, 3/4" is 19.05mm.
Aaron Z
/ Document preparation fees--RIPOFF #132
Aaron Z
I thought Dodge has made tires an option on their new trucks
/ Document preparation fees--RIPOFF #133
Aaron Z
I call hogwash.
I use those sockets interchangabally all the time. Most tire irons are even double stamped on one socket 19mm-3/4.
250lbs on a 4' bar is 1000ft-lbs of torque not counting the bouncing. Those nuts should have only been tightened to the 100-120 range. They were too tight or seized and THAT is what broke your socket. NOT the fact that it as 0.05 mm smaller. And for those that dont know, that is only (0.002")
I doubt the tolerance on your sockets are even within two-thousanths of an inch.
Hows that for off topic??
going from doc fees, to a little disagreement, to some math, metric-inch conversion, and the tolerance of a 3/4 and 19mm socket:D
/ Document preparation fees--RIPOFF #134
I call hogwash.
I agree.
I didn't say anything at the time as I didn't want to say something, then later regret it, but I know that he was feeding me a line of BS, HE knew he was feeding me a line of BS, but I dont know that he know that I knew he was feeding me a line of BS.
This is the same place that put 3 waterpumps on that truck in less than 2 years. Since I came into the family, it has not gone back there. If I cannot handle the job, it goes to a small independent shop who is busy enough that they schedule a week out.
Aaron Z
/ Document preparation fees--RIPOFF #135
As a duly recognized instigator of some renown, I have been approached by certain interested parties to ascertain the most direct and effective mean to direct this thread further from the original intent and purpose.
To this end I have studied most vociferously the Obama Health Care Plan documentation, an original copy of the elusive Birth Certificate for aforementioned plan author, political plans and affidavits for the Perry Presidential campaign and certified photographs of the infamous "painted" rock and have conclusively determined that I agree with the honorable gentleman from Maine in that ............ You can't get there from here.
My bill is in the mail gentlemen. Thank You very much.
/ Document preparation fees--RIPOFF #136
This is well thought and informative bunch of cra*. Congratulations on another fine post that is both uninformative and insightful at the same time. I agree that the birth certificate actually belongs to Arnold Schwarzenegger and not obama. Its this document that has caused the global colapse as we know it. That and snow in the tires.
/ Document preparation fees--RIPOFF #137
Well Gentlemen, your posts prove beyond a shadow of a doubt something I always suspected..........
HST is BETTER than GEAR every day of the week.........
that begins with a vowel!
/ Document preparation fees--RIPOFF #138
Talking about Dodge lug nuts gets me all worked up. Don't forget that on older Dodges, the drivers side lugnuts were left hand thread.
/ Document preparation fees--RIPOFF #139
My first new car was a 89 S-10 Blazer. 4.3L 4x4. What a POS. Anyway about 3,000 miles into having it I got a flat tire. Drivers rear. I got out and it had a fork in it, literally. It was a kitchen fork and all 4 points put holes in the factory Tire Paws. Another POS. Thanks GM.
Anyway, I could not get the lugs off. I walked a mile to a farmers house on a Sunday. Luckily they had just got home from church and were having lunch. They gave me a plate and told me they would give me a hand when I we all got done eating. This was before the days of cell phones. Anyway, after lunch he got his truck and sent me to the barn to get a piece of 6' fence pipe that way laying along side the barn. I had also used their phone to call my dad. He meet us at the truck and the 3 of us managed to lift the trucks rear wheel off the ground using the lug wrench and cheater bar. If that POS was built half as tough as the lug wrench it may have been a decent truck. My dad said screw it and told me to drive it the 7 miles to the GM dealer on the flat tire which I did. It ate the wheel all up and destroyed the tire.
I got a call the next day and they told me they were going to have to order 4 new wheels and all new studs. They could not get them off and ended up having to burn them off with a torch. I have no clue how tight they were but the truck only had about 3,000 miles so it had to be that way from the factory.
Chris
/ Document preparation fees--RIPOFF #140
Except sundays. Which is a day of rest in which the tractor does not work. So on that day, the cheaper Gear tractors reign king:thumbsup:
