Do your own Fluids and Filters on a BX
   / Do your own Fluids and Filters on a BX #142
hmmm,
Wix claims to have a cross for the HHK20-26990 hyd filter in my GR2120, but not for the HH150-23430 in the BX24. I'd have thought it would be the other way around, if they had anything.
@Tractor Seabee, I was idly reading your post over on "Plowing feed plots..." when I came a cross "blackberries". Howdy neighbor. Looking forward to that hyd filter number.
[edit] Simultaneous posts :) Thanks for the info.
Z.
   / Do your own Fluids and Filters on a BX #143
Good info in this thread, marking it for future posterity. :)
:2cents:
WIX part numbers:
Fuel Filter = 33972
Air Filter = 46449
Oil Filter = 51365
Hyd Filter = 57088
:thumbsup:
My RTV1140 will need its 50 hour service this summer. Believe it will be just as easy or easier to do since bed raises and it looks like it's all right there in easy reach.
   / Do your own Fluids and Filters on a BX #146
If you had the mmm off would jacking up on side that the hydro screen is on would prevent any fluid from coming out when you cleaned it for 50 hr service I have a bx 2360????
My BX25 will need 2yr & 400hr in April, dealer service time?
No. Do it yourself and save a few hundred dollars. The dealer won't do anything more than you will/can do and maybe even less. They will just let fluids drain in between other jobs and replace filters in between other jobs. I won't require their smartest mechanic to do the fluids service, see what I mean? Plus your taking it in, leaving it till they get time in the schedule and then going back to get it or paying someone to do the pick up and delivery.
I don't think so unless you turn it on its side. Just get the cork and don't worry about losing a couple of cups of fluid.
Learn your machine from looking up at it.:thumbsup::)
   / Do your own Fluids and Filters on a BX #149
hmmm,
Z.
Zol, the whole NAPA # is 557088 in case you did not pick up on it earlier.
Ron
   / Do your own Fluids and Filters on a BX #150
Remember the good old days when some filters had a nut welded to the top for easy install/removal with a socket wrench.......... I'm going to do my fluids and filters this week. 520HRs on my BX22. This is thing I ever purchased. I should have purchased it years ago (got it in 2006). Snow, dirt, mulch, cut wood, bricks, stone, trenching............NO MORE BACKACHES!!!!!!!!!!!!!!!!!
I even got the 60" belly mower and took it off and put it in storage in the garage for more clearance room.
Anyone looking for Parts/diagrams PDFs on the BX22, LA210 and BT600 email me and I will send you the ones I found. Pics and part numbers:thumbsup:
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Unverferth 25' Head Cart (A59814)
Unverferth 25'...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
