Mowing Do your Mower a favour and clean your deck!
   / Do your Mower a favour and clean your deck! #21
What kind of blades are you using? My dixie chopper blades have 800 hours on them, and are barley worn.
797696 For 54" Cut With Fusion Scroll down on this page. It is the OEM blade. I just put on a new set.
Excel / Hustler Mower Blades
Bahia grass and sand is like taking a grinding wheel to them, and I got plenty of each - and the gophers like to help pile up the sand also.
I usually have to go over the yard 3 times to knock it all down, it's brutal. It does not need watering or fertilizer and it's better than just sand. So what I save in irrigation and fertilizer I spend in blades. Always trade-offs.
   / Do your Mower a favour and clean your deck! #22
I don't disagree that a clean deck, and sharp blades mow better. I am just not going to clean my deck every time I mow, and sharpen the blades every 5 hours of mowing. My blades don't dull very much in 5 hours. My finish mover blades take a severe beating because I only use that mower for rough places, and I don't even try to keep those sharp. My Dixie chopper blades that cut only grass (mostly) hardly look dulled after 5 hours of mowing. I also think the fabricated deck on mine and most other high end zero turns collects less grass buildup than a stamped deck.
   / Do your Mower a favour and clean your deck! #23
I've got a 61" 2004 Scag Turf Tiger with the 27LC Kawi. Had the original Marbane blades on there for years with a ridiculous amount of abuse from limbs, large hidden rocks, and metal pipe covers. Time after time I would check the blades just knowing that I had pretzeled one but they were always good and rarely needed sharpening. I finally bent one on a grass filled hole with a large concrete block in it. Went to the G6 and bent three of them in 6 months and the blow out from the front seems much worse. The next time I replace the set it will be back to Marbane. Mine only has the Advantage deck and not the better Velocity or Velocity Plus decks but the Marbane blades would cut it like a hot knife through butter. The turf looked perfectly groomed. With the G6 blades it seems like I'm always left with stringers especially on thin, sparse grass.
As for cleaning the deck. I usually turn the blades on and set something heavy on the seat (I know, I know) and put the hose nozzle on "jet". Only do that with cool spindles. That knocks 95% out and will turn your legs and feet green but to be honest I rarely have much buildup any more unless I mow in really wet grass. I took some good advice years ago and cleaned it really good one time and coated the bottom of the deck with Fluid Film. It made a big difference on my mower.
   / Do your Mower a favour and clean your deck! #24
Where do you get Marbane blades?
   / Do your Mower a favour and clean your deck! #25
"Marbain", try a google search, only blades I'll use. Cost about twice as much, last 4+ times longer.
   / Do your Mower a favour and clean your deck! #27
PICKUP TOOLBOX (A58214)
PICKUP TOOLBOX...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
David White Meridan LT6-900 Level Transit, S/N D94224 (A59076)
David White...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
2022 JOHN DEERE 624P WHEEL LOADER (A52709)
2022 JOHN DEERE...
2020 Topcat 48" Hydraulic Articulating Skid Steer Cutter, S/N BORC20120101, Asset# 69 (A59076)
2020 Topcat 48"...
