Do you Super Glue aerosol spray straws on??
   / Do you Super Glue aerosol spray straws on?? #1
fidowanttobe
Platinum Member
Mandan ND
Jinma 284 2007 Massey Harris 44 Special
Co-worker freaked when he saw me glue the straw on a brand new can of spray. "Wow! I'm gonna start doing that too!"
Been doing it since the beginning of time. Always missing if I don't. Just assumed everyone did.
Tip: if the can and/or straw is used, clean them with choke cleaner first.
   / Do you Super Glue aerosol spray straws on?? #3
That has never even crossed my mind but thanks for the very good idea.
   / Do you Super Glue aerosol spray straws on?? #4
YES, YES, YES,! What a fantastic, simple solution! I am always looking for them when they fall off....
   / Do you Super Glue aerosol spray straws on?? #6
How do you keep the super glue container usable after such a small amount dispensed?
Thanks!
   / Do you Super Glue aerosol spray straws on?? #7
I buy cases of the Brake Cleen (I think) spray. Usually each can comes with the spray straw taped to it. Latest case came with no straws at all. My guess is that, due to supply shortages, that may now be the norm.
used to throw the straws away; now I have to scrounge and save.
I have 2 duct tape “pockets” inside the aerosol cabinet door that holds extra straws and caps. Also a stack of funnel caps off quart of 80/90 style. Work great for propping small parts when painting. My kids are gonna think I was a hoarder.
   / Do you Super Glue aerosol spray straws on?? #9
Great tip!
One I discovered is Blow Off spray is cheap at Walmart. Some fine soldering jobs (electronics) heat and blow solder away. A toothbrush removes splatter.
Holding can upside down you get freeze spray (I've removed warts with it ).
2011 PETERBILT 348 (A52472)
2011 PETERBILT 348...
2013 BIG TEX BIG TEX (A52472)
2013 BIG TEX BIG...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2020 KENWORTH T680 SLEEPER TRUCK (A52576)
2020 KENWORTH T680...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
