Front-End Loader Do you store your implements & FEL Outside??
   / Do you store your implements & FEL Outside?? #11
outside covered with organic tarp (leaves) a few are under organic shelters (trees) and some are protected by security gaurds (bees)
   / Do you store your implements & FEL Outside?? #12
Tractor under a tarp. Rotary cutter, box blade and FEL outside using the same elements as firemanpat.:D
I'm planning a pole barn. Start date keeps getting backed up by petty little things money, but I'm shooting for this fall. Will be very simple. Three ten foot bays across the front, 20' deep, open on all four sides. Using 6x6 pt posts. Will have 12 feet of clearance on front and 9 at the back. The only way I could get funding from the CFO was to make one of the bays into a stall for the horse, which in my opinion is a capital waste of tractor/implement storage, but what can you do?
And, I've never built anything of substance that I designed. I built my log cabin myself but it was a kit. So, I suspect I'll over build this thing, but I'll be looking for advice from this august group in the next few months.
   / Do you store your implements & FEL Outside?? #13
Stuff that has moving parts: Inside on pallet rack. Stuff w/o moving parts outside.
exposed Cylinders: inside. As on my BH and rear blade.
Driveline/ gear cases: inside. as on mower and tiller
spinning disk: outside. as on disk harrow
Tractor: inside. unless return to use <24 hr.
semi-moveable: outside. as on the KK rear rake.
Stuff that is seasonable such as mower, tiller is on the pallet rack until in use, will be cleaned and maintained prior to being replaced on rack in fall.
   / Do you store your implements & FEL Outside?? #14
Everything inside, I hate faded paint and things that don't match. It must be the Girl in me
   / Do you store your implements & FEL Outside?? #15
The 4' bush hog is outside and the PHD is dangling from a tree limb but everything else, tractor, FEL, box blade, sprayers, spreader, are all kept in the attached garage. It's not fully enclosed but it keeps the weather off them. My wife tells me that I need to get them all out of there but until I can get the storage building up, there they will stay. I've put my foot down and as long as she agrees, that's the way it will be.
   / Do you store your implements & FEL Outside?? #16
BH - inside
Tiller - inside
Rake - outside under sun
Everything else - under awning out of sun and direct rain.
   / Do you store your implements & FEL Outside?? #17
Everything inside a 40'x8'x9.6' conex (metal ocean container). Wind and weather tight and somewhat secure.
Bought this thing for about $1700 and $225 to have it delivered. I could not put up a barn or building this size and as secure for that price.
Look up Chassis King - for more information. I can say that I'm really happy with this storage solution.
On a side note, I do know these are going up in price due to the US gov buying a LOT of new ones and shipping them to Iraq and the like for storage for military items. These formerly were about $500-$800 but now probably are up in the $2000-$2500 range.
If anyone wants more info, let me know.
Dave
   / Do you store your implements & FEL Outside?? #18
Yep, I've got a 40' High Cube for my stuff
   / Do you store your implements & FEL Outside?? #19
i barn everything i can. if you go to sell eventually, i imagine it will help hold some value.
   / Do you store your implements & FEL Outside?? #20
Went with the high cube also. I can back the tractor in with the Rops in the up position.
Just need to get a coat of paint on it now. I think my boys should be able to handle that for me :)
Dave
24in excavator tooth bucket (A56435)
24in excavator...
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
RoGator RG1100C (A56435)
RoGator RG1100C...
2014 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2014 Chevrolet...
