Do you only use JD oils/greases?
   / Do you only use JD oils/greases? #1
JDTank
Platinum Member
Just wondering if people strictly use only John Deere grease and oil on their garden tractors?
My dealership is a 45 minute drive, one way, so either I stock up on oil, or I buy other stuff from my work. I am partial to the Amsoil synthetic grease we use at work, and was thinking I would use that on my X740. As far as oil goes, I am going to stick with the JD break-in oil for 100 hours, but after that, I was thinking of using something else besides John Deere oil.
Does anyone know who makes the JD oil and grease anyways? I'm sure it's just another brand that has a JD label on it.
   / Do you only use JD oils/greases? #3
I buy red grease by the carton, usually Valvoline Crimson and Delo 400 engine oil 15w40. The filters, transmission oil and antifreeze are Deere. Batteries are agm Odyssey when I can find one that fits.
   / Do you only use JD oils/greases? #4
Pretty sure their POL products are Chevron. And it's my understanding that - whereas many mineral oil greases are not compatible with each other - synthetics are universally compatible. I have an X500 and a 3720, and use aftermarket consumables on both. That said, they must be labeled to meet or exceed the pertinent JD spec
//greg//
   / Do you only use JD oils/greases? #5
Grease is mostly Lucas and Jesco
   / Do you only use JD oils/greases? #6
i use all jd stuff...it just makes it easy what to use for what and compaired to the cost of a tractor and since im doing it myself it's not that much money in the grand scope of things
   / Do you only use JD oils/greases? #7
I use JD for the hydrostatic drive. For everything else, as long as it meets or exceeds the JD spec I will use other products than JD that I have faith in.
1985 International 1754 Material Spreader Dump Truck (A51692)
1985 International...
2020 CHEVROLET SILVERADO TRUCK (A51406)
2020 CHEVROLET...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
2000 FORD E350 CUTAWAY BOX TRUCK (A54313)
2000 FORD E350...
KUBOTA M6800 UTILITY SPECIAL TRACTOR (A51406)
KUBOTA M6800...
2003 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2003 FORD F350 XL...
