Do you need to purge air out of the hydraulics?
   / Do you need to purge air out of the hydraulics? #1
Dedaisy
MA
RTV-1120D, JD 5085M, Montana t7074, JD4300, JD4700, Kubota RTV900, JD 6x4 Gator, JD HX 2WD Gator, Terex HR16,JLG 40E Bloom lift
I've just repaired a piston on my tractor's loader wondered if I needed to purge the air out before reinstalling? and just how do you do it?
   / Do you need to purge air out of the hydraulics? #2
Just cycle the cylinders through several times. The air will be forced out.
   / Do you need to purge air out of the hydraulics? #3
On a loader you typically do not have to purge the air from a cylinder. Normal procedure by most people is to install the cylinder and then cycle it through its full range of motion several times. Be sure to check your oil level after doing this. Depending on the cylinder size it could take 1/2 gallon or more to fill it.
If you want to try and bleed the air out before connecting the lines you should have a helper that you trust.
What I do is have the cylinder fully retracted.
Connect the hose to the cap end of the cylinder.
Plug the hose that goes to the rod end to prevent oil from coming out.
Using the tractor hydraulics slowly extend the cylinder fully while watching so that it doesn't catch or bind on anything.
With the cylinder fully extended shut the tractor off and release any pressure in the lines.
Connect the rod end hose and not the cylinder should be very close to full of oil.
Now you have to use the tractor hydraulics to very carefully line up the pins.
Thanks... It is one of the two main lifting cylinders on the 7074 Montana. Bad weld on the end bushing broke. It has a ~ two inch shaft and the guy who had this tractor before did not grease it very often.. Got to replace the pin also. I had already replaced most of the pins on the loader...
   / Do you need to purge air out of the hydraulics? #5
Will it be the same for me with 8' of hoses, a new cylinder, and valve?
   / Do you need to purge air out of the hydraulics? #6
I've had one of the loader cylinders off and repaired, all I did was cycle the cylinder to the end of it's travel, then let the pressure go over the relief valve for about 15 seconds. After a couple times doing this each way there was no air remaining in the cylinder. Just where the air gets to baffles me though, it would have to go past the seals and into the reservoir... :confused:
Sean
   / Do you need to purge air out of the hydraulics? #7
I had a few bad pins in mine when i bought it. You can buy the nice ones at TSC, with an oval handle.I could not find pins with zerts, so I bought cold-roll 1018 steel and drilled my own grease passages into them. just a thought. Jy.
2003 Chevrolet Silverado 2500HD Pickup Truck (A53117)
2003 Chevrolet...
2008 Diamondback 15ft. Air Boat with S/A Aluminum Trailer (A51694)
2008 Diamondback...
2012 Ford F550 (A52377)
2012 Ford F550...
LINDE WELDER (A53843)
2016 Ford F-250 Ext. Cab Pickup Truck (A53422)
2016 Ford F-250...
