Do you have a horn or other audible on you tractor?
   / Do you have a horn or other audible on you tractor? #12
Stock on my NH TD5030.
I've been thinking about adding one and trying to come up with a workable solution.
   / Do you have a horn or other audible on you tractor? #14
i had a stock one on my Dk45 cab, but it sounded exactly like an old 60's era VW bug. So i ditched that and replaced it with a 2 stage electric horn...way better
   / Do you have a horn or other audible on you tractor? #15
Most of my tractors had horns albeit one that sounded like they belong on an Austin Mini.
I really need to upgrade some of them. Very, very usefull to get someones attention. Then you play this game that's called "I see your lips moving but I can't hear you".
   / Do you have a horn or other audible on you tractor? #16
I was surprised that my Kubota L3830 didn't come with one, so I got a horn from an auto parts store, and a push-button switch with a weatherproof cover which I installed on the dash. Mounted the horn behind the grill next to the battery.
I like the idea and seems to make sense. I will check out some options.
   / Do you have a horn or other audible on you tractor? #18
If you wire the hot (+) lead off the battery, don't forget an inline fuse.
   / Do you have a horn or other audible on you tractor? #19
not hard to put 1 on. just find a good car horn. i mounted mine behind the grill. run a wire to a push button starter switch from the battery or key switch. then on to the horn. your ready to make the cows move out of your way.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2011 SHOP MANIFOLD TRAILER (A58214)
2011 SHOP MANIFOLD...
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A56858)
2012 Freightliner...
WERK-BRAY 23" PIN ON BUCKET (A52706)
WERK-BRAY 23" PIN...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
