Do you Floss regularly?
/ Do you Floss regularly? #1
gotrocks
Platinum Member
Phenix City Alabama
B-2910 delivered 8/23/01
To keep my teeth healthy on the FEL I have started flossing when I can.
Here is one view. Any other suggestions?
/ Do you Floss regularly? #2
Wow an industrial strength floss applicator.
/ Do you Floss regularly? #3
HEY MAN! It looks like nobody is on that rig. What is holding the backend down? /w3tcompact/icons/eyes.gif
/ Do you Floss regularly? #4
Clementine flosses, but has no teeth!
Pete
/ Do you Floss regularly? #5
floss free version
/ Do you Floss regularly? #6
Neat Rig NS, how did you build that? Any plans for building one?
/ Do you Floss regularly? #7
Do not have any plans. Designed during building process. One or two changes after maiden voyage.
Pipe is 2" schedule 80.
Will attach another picture or two if it might help with your plans.
/ Do you Floss regularly? #8
Rear view.
I used 1-3/4" solid bar for the fulcrum ( I think that is what you call it) & 2" schedule 80 for all pipe. Installed grease zerts where needed. I wanted it to where I could remove the closing arms if needed to repair or just wanted them off. I first used 1/2" soft bolts for shear bolts, then #5, now on #8. So far have not sheared any #8 nor torn up any equipment because of them.
/ Do you Floss regularly? #9
Seeing all that paint on the bucket are you sure it's time to floss?
Egon
/ Do you Floss regularly? #10
Man, that's some hunk o' lumber, Pete! /w3tcompact/icons/shocked.gif What kind of wood is that?
Couldn't help but notice a certain similarity in that pict and the one I posted recently. Considering we live about as far apart as you can get and still be in the same country, it's amazing that our cameras seem to see the same thing.
See attached.
Ditch Witch 6510 DD Trencher 4x4 (A62613)
Ditch Witch 6510...
2018 LANDOLL 330 S/A  DROP DECK TRAILER (A59912)
2018 LANDOLL 330...
2016 Hyundia 53' Dry Van Trailer (A62613)
2016 Hyundia 53'...
2003 Kenworth W900 L Model (A62613)
2003 Kenworth W900...
2020 CASE TV450B SKID STEER (A64279)
2020 CASE TV450B...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
