do you drain water from the fuel filter before the dash warning lights?
   / do you drain water from the fuel filter before the dash warning lights? #11
Right or wrong I don't.
The filter will separate the water, water is heavier and will settle to the bottom. Water at the bottom will trigger the light. So I guess I'm relying on the technology to perform as designed.
My older tractors had a sight glass and I only drained if water was present. Never had to drain except to change the filter.
If you buy your fuel from a high volume source you should be okay. From what I see, more water issues have been from the pump/supplier than from condensation issues.
2006 Cummins DGBB 35kW Standby Diesel Generator (A56857)
2006 Cummins DGBB...
Hose Reel (A55787)
Hose Reel (A55787)
Hose Reel (A55787)
Hose Reel (A55787)
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
2017 Ram 1500 SLT Crew Cab Pickup Truck (A56858)
2017 Ram 1500 SLT...
Greenworks 2700psi Portable Pressure Washer (A56857)
Greenworks 2700psi...
