Do you discharge a battery a little before you charge it?
   / Do you discharge a battery a little before you charge it? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
When I was a kid helping out is a shop, the meticulous owner told me to ALWAYS turn the lights on for two minutes before a battery charge to drain off surface resistance to a charge.
Is this a wive's tale?
   / Do you discharge a battery a little before you charge it? #2
Draining the surface charge is necessary prior to testing a freshly charged battery, but I have never heard anyone say to do that prior to charging a battery.
For batteries that I want an accurate test on, I let them sit for 24 hours before testing.
   / Do you discharge a battery a little before you charge it? #3
I worked in two dealerships (VW & Pontiac) in an earlier life. No one ever said to discharge a lead-acid battery before charging. Although the testers of the day did just that. They were nothing but a carbon-pile resister and two gauges--Amp and volts. There was no cool electronics like they have today in hand-held testers.
   / Do you discharge a battery a little before you charge it? #4
I'm calling wives tale on that. Another tale I used to hear was completely drain the battery before charging. Science has proven that batteries have a cycle life. If a battery has a cycle like of say 1500 full recharges, then it has a life of 3k 50% recharges. And everything runs better, draws less amperage, on a full charge vs low voltage. Less amperage draw reduces motor and component heat increasing efficiency.
   / Do you discharge a battery a little before you charge it? #5
And yet the old carbon pile load testers are still the most accurate way to see if a battery is actually serviceable! I use a fancy electronic tester to track batteries over time only.
   / Do you discharge a battery a little before you charge it? #6
Maybe a confusion with NiCad batteries which were to be discharged before recharging otherwise they developed a “memory” of the charge point, and would drop voltage faster after that discharge point on subsequent uses.
   / Do you discharge a battery a little before you charge it? #7
Other than what DarkBlack mentioned, I never heard of discharging a battery except by simply using it normally. What would be the pointy of charging an already-charged battery?
   / Do you discharge a battery a little before you charge it? #8
Yes but, NiCad is an obsolete medium.
LiFePO4 battery composition is way better, IMHO.
   / Do you discharge a battery a little before you charge it? #9
And the LiPo batteries don't need to be discharged. They keep going until dead anyway. I've been converting all my battery hungry items to rechargeable LiPo. Their output is a straight line on a graph then drops off instantly. I especially like the rechargeable AA and AAA batteries now. They output 1.5-1.6v. Not like the old NiCad of 1.2v fully charged.
   / Do you discharge a battery a little before you charge it? #10
This is interesting but seems to have digressed from the original question. I have nothing definitive to add but thought the surface charge was on a fully charged battery actually putting it a bit above the stated battery voltage. That being the case why would one want to charge a fully charged battery?
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2012 Ledwell 130BBL Vacuum Trailer (A50860)
2012 Ledwell...
2022 JCB HM180T Hydraulic Breaker Excavator Attachment (A49461)
2022 JCB HM180T...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
1271 (A50490)
1271 (A50490)
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
