Do You Cover Your Vertical Exhaust Stack Tip While Trailering?
   / Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #31
I'd sure would love to get a detailed explanation of this. A vacuum doesn't necessarily equal air movement. It just means negative air pressure. That would be held held constant if both inlet and outlet is sealed. Not sure how a turbo (fins) move without some type of air flow through the system. Don't buy that one open valve is going to create damage.
Yep, mechanical logic overrules opinion in this case.
And actually, you must have two valves open, intake/exhaust, in the same cylinder..... That is only possible by camshaft overlap. This overlap varies depending on the use of the engine. But in the most extreme case it's minimal at best. And will never have both vales open completely.
Would be interesting to hear a diesel mechanic explain it. Maybe I'm missing something..... :confused3:
   / Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #32
i am a lowboy driver and haul machinery of all types; brand new, and older. I also work for a major brand dealer of large excavators. we never cover stacks on anything when we move them. i deliver almost million dollar machinery accompanied by a dealer rep and no one has ever said anything
   / Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #33
I know when my dog has his head out the truck window, his lips blow up and he farts more!:laughing:
   / Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #34
His cam must have a LOT of overlap holding 2 valves open at the same time!!!! :)
   / Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #35
HOT, HOT, HOT. boy I asked that question years ago and boy did it start a feud. I have since been converted to covering the stack.
   / Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #36
It seems to me regardless of the turbo issue, I do not want dirty air going in the engine so I always cover mine when its on the trailer. If that is not a problem for you leave your air filter off of the intake and see how long your engine lasts.
   / Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #37
I always thought covering the exhaust to protect the turbo was sort of an urban myth type of thing, but having my own equipment now, as long as turbos cost more than duct tape I'll take the precaution.
I like the nerf football idea, I'm going to try that one out.
   / Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #38
That's not even close to the same thing.... :confused3:
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2018 Ford F-150...
New/Unused Gold Mountain 12ft x 20ft Steel Carport (A57454)
New/Unused Gold...
2007 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2007 INTERNATIONAL...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
Mini John Deere Truck (A55853)
Mini John Deere...
