Do wood chips spontaneously combust?
   / Do wood chips spontaneously combust? #21
Remember the old movie "Fahrenheit 451". It was titled for the temperature at which paper combusts. I imagine wood is about the same.
   / Do wood chips spontaneously combust? #22
Fuels and Chemicals and their Ignition Temperatures
I think, and I am guessing at this point though, that anything like large piles of wood etc, are not "pure" or such, and those impurities will raise or lower the autoignition temp accordingly.
Picturing large piles of wood chips etc. I just doubt that other things would not be in there as well.
   / Do wood chips spontaneously combust? #24
BigE_ said:
I'm not sure this reasonably describes what happens in a wood chip or sawdust pile. They are describing the second stage of combustion in a wood burning fireplace. Very big difference.
Someone else in this thread has already cited a much lower number for spontaneous combustion. I'd like to see their source.
Bottom line is, piles of sawdust and woodchips do combust. Ample evidence had been cited for that. If it has to be 450 degrees for that to happen, then it must reach 450 in those piles. I think that is highly unlikely though and suspect that for whatever reason, whether its impurities or differeing properties for sawdust and decaying chips, that these piles ignitie at far lower temps than 450 degrees.
   / Do wood chips spontaneously combust? #25
It's highly likely that during the decomposition of the wood and other items in the pile, that some combustible gas such as methane is given off. That byproduct could ignite at a much lower temperature and then ignite the other products.
   / Do wood chips spontaneously combust? #26
My somewhat educated guess is that the decaying wood produces gases that ignite at much lower temperatures. Once those gases ignite, I'm sure it is easy to reach the 540 degrees cited in the article above for the actual wood to burn.
   / Do wood chips spontaneously combust? #27
Guess orezok and I had the same thought at the same time....
   / Do wood chips spontaneously combust? #28
The actual wood doesn't burn, its the gases...:D :rolleyes:
Pyrolysis: The process also occurs when burning compact solid fuel, like wood. In fact, the flames of a wood fire are due to combustion of gases released by pyrolysis, not combustion of the wood itself. Thus, the pyrolysis of common materials like wood, plastic and clothing is extremely important for fire safety and fire fighting.
   / Do wood chips spontaneously combust? #29
I have tons of wood chips ever year. They never ever came close to burning.
Don't worry.
Bob
   / Do wood chips spontaneously combust? #30
Well this isn't about wood chips but it is kind of funny. A buddy of mine loaded a farm wagon with fresh hay and they decided to park it in their metal storage barn - with lots of other equipment. Luckily, they put it in the middle of the barn and it was not near anything else. They weren't in the barn again for about 2 weeks - they opened the door and found a pile of ash and metal wagon parts. They never knew if the thing just smoldered down to nothing or if there was a blaze. Lucky that nothings else caught fire.
On the not funny side: My uncle lost a 150 year old barn about 3 years ago to a hay fire. That one was very sad as it basically sent him out of the dairy business and shut down a 80 year old family business. I would think that if hay can spontaneously combust, wood chips can as well - but it may be a big less likely just because they are probably harder to ignite.
BUSH HOG 1815R1 BATWING MOWER (A51247)
BUSH HOG 1815R1...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
UNUSED AGT SDA 140W WHEEL LOADER (A52706)
UNUSED AGT SDA...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
2007 CHEVROLET C4500 DUMP TRUCK (A51406)
2007 CHEVROLET...
2017 Ford F450 Reading Service Truck (A55788)
2017 Ford F450...
