Do they make trench digger attachments?
/ Do they make trench digger attachments? #1
AgentWD40
Davis, Ca
Do they make trench digger attachments for compact tractors? I have a Kioti LB1914 (17 PTO HP). Is this enough power to run one of these attachments?
Also, what brands/type are best to get? How much do they normally cost? I'm looking to use one for puttin in sprinkler pipes. Thanks.
/ Do they make trench digger attachments? #2
You could use a subsoiler. They dig narrow trenches down to about 12" max. Big enough for sprinker work I would think. They run about $140.
/ Do they make trench digger attachments? #3
Don't know much about brands, but yes, 3PH trencher attachments are available. I believe they are quite expensive, though. On the way to work last week, I passed by one mounted on a tractor.
OkieG
/ Do they make trench digger attachments? #4
ARP made one called a trench hog. Not sure if they/re still available. Depending what your burying subsoiler will work for small dia and single moldboard for bigger dia stuff . A 3pt hoe would be much more versatile than trencher for probably same price.
How do most people dig trenches for this sort for work? With a backhoe attachment? What attachment would you recommend to do this project?
Does a subsoiler actually clear the trench? Or does it just break the dirt up and you clear it by hand? Would a 3PH hoe clear the trench as it dug it? Do the trenchers you rent from the yard actually clear the trench as they dig?
/ Do they make trench digger attachments? #6
I do not believe a sub-soiler will clear the trench. There have been some very innovative uses of sub-soilers in various threads, for laying long lengths of coiled pipe. For placing discrete short lengths of pipe, like for your sprinkler system, a trencher would do a better job, in my opinion. A backhoe would work, but is way overkill, leaves too wide a trench, and is not fast.
The sprinkler service that put in our sprinkler system used a walk-behind trencher unit, that dug almost as fast as the installer could walk. They layed the pipe in no time. A rental yard might have one of these machines. I don't think using a 3PH version would have gone any faster or easier. Trenchers will clear the trench as they dig.
OkieG
/ Do they make trench digger attachments? #7
</font><font color="blue" class="small">( Do the trenchers you rent from the yard actually clear the trench as they dig? )</font>
They clear it pretty well, but not perfectly, and to some extent it may depend on how wet the ground is. The ones we've rented have worked quite well.
/ Do they make trench digger attachments? #8
Yes they do make 3pt, cat 1, pto powered trenchers, search here at TBN for more information, and an internet search for dealers. I did this some time ago when myself and my neighbor talked about buying one about $2500 for 18" max depth, or $3500 for 36" max depth. We (I) decided we could do alot of renting and sharing for $3500. Also they say here and dealer sites must have hydro or be extremely quick on that clutch running one 36" deep. As both me and my neighbor own gear tractors, another concern even if we wanted to spend our money. I think I agree with what was mentioned earlier for a sprinkler operation a walk behind might be more versatile.
/ Do they make trench digger attachments? #9
I just purchased a Middle Buster just for that purpose. I have to dig two trenches to lay electrical conduit, and felt that I could make two or three passes to get it deep enough for what I need. Both trenches are going to be over 100 feet, and this Georgia red clay makes using a shovel impossible, especially if the ground is dry.
I'm still a few weeks away from laying the conduit.
Regards, Les
/ Do they make trench digger attachments? #10
Bolton Power Equipt. has one of chinese orgin, $1495.00. His site states that it requires 21 pto hp. He is a member on TBN. Do a search for Boltonpower if you're interested. I'm sure he'd check to see if there is a smaller version available.
/ Do they make trench digger attachments? #11
If you're patient something will turn up. I found a DuAl PTO trencher on eBay that no one wanted a little over a year ago. As long as you're not trenching to the maximum depth, you may be able to run a larger trencher on a smaller tractor.
/ Do they make trench digger attachments? #12
</font><font color="blue" class="small">( How do most people dig trenches for this sort for work? With a backhoe attachment? )</font>
Check out this thread by DK35vince. He used his Kioti DK35 TLB to dig trenches for some utility lines. He did a great job.
Here is the link:
Utility line digging begins
I would also not recommend a 3PH backhoe. They put too much stress on the tractor frame. In some cases, people have even broke their machines in half. You should consider a backhoe with a subframe that mounts to the tractor. That way, any stress is put on the backhoe subframe.
/ Do they make trench digger attachments? #13
</font><font color="blue" class="small">( Does a subsoiler actually clear the trench? Or does it just break the dirt up and you clear it by hand? Would a 3PH hoe clear the trench as it dug it?)</font>
I've seen pics on here of someone using a subsoiler with a 90 degree PVC elbow attached to the back side and a coil of wire being fed into it as it is being dug. That might work for sprinker lines as well. It looked pretty slick and the whole operation was done in one pass.
/ Do they make trench digger attachments? #14
I know Kubota makes one. They say it is compatable with the B2410 but not the B2400 (18 PTO hp) for some reason. With that orange paint it's likely to be expensive.
I used a rental walk behind trencher (should that be a walk-in-front-of trencher since you are going backwards /forums/images/graemlins/smirk.gif) to lay water lines to both my wife's and my garden this spring. The rental wasn't too expensive per day (less than a $100 I think) and you can cut a lot of trench in a day with it. Even the big ride on trenchers weren't all that expensive. I used the tractor FEL and box blade to fill it in and tamp it down after I'd finished laying and testing lines.
If it were me, I'd mark out where my lines are to go with spray paint one day, rent a trencher early next morning and have at it. Even a big installation shouldn't take more than one days rental and it should bury them deep enough to prevent freezing, especially if you design it so you can drain the lines before winter.
/ Do they make trench digger attachments? #16
Re: Do they make trench digger attachments? *DELETED*
Post deleted by hockeyhead
/ Do they make trench digger attachments? #17
hockeyhead, that link didn't work. Could you try again? Thanks, John
/ Do they make trench digger attachments? #19
/ Do they make trench digger attachments? #20
File Not Found
The requested URL was not found on this server.
This is all I get. Are you copying and pasting? That works best. John
2008 Lexus IS250 Sedan (A61569)
2008 Lexus IS250...
KSI Conveyor (A63118)
2002 Freightliner FS65 Chassis Bus, VIN # 4UZAAXAK02CK16471 (A61165)
2002 Freightliner...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2006 Ford F-150...
1991 INGERSOLL RAND DD-24 SMOOTH DBL DRUM ROLLER (A62129)
1991 INGERSOLL...
2023 HANGCHA CPYD30-XW71F STRAIGHT MAST FORKLIFT (A62129)
2023 HANGCHA...
