Do smart electric meters alert the power company when it's removed?
   / Do smart electric meters alert the power company when it's removed? #11
So what is the procedure to get the meter pulled?
I often work as a helper doing HVAC and when the condenser disconnect needs replacing the guy just pulls the meter. Haven't heard of any ramifications from the short duration disconnection and know a few of the people who would have said something if the power company ever questioned them about it later. I would assume if the meter doesn't come back online the power company would eventually check to see if someone was stealing power.
You just call the owner company, get a date and time, and go from there. Usually the lineman turns up and asks how long you need it out, and either stays (e.g. a
Something quick like replacing the siding under the meter), or comes back in the afternoon or whenever you want it. Quick and easy in my experience.
Besides the possible penalties, look up arc flash;
I'm not saying you might get lucky, but I am saying it is very much not a zero risk endeavor pulling a meter without safety equipment.
All the best,
Peter
   / Do smart electric meters alert the power company when it's removed? #12
They will know. The display quit working on my smart meter, it notified the electric coop. They sent a service guy out to replace it. When the power goes out, I get a notice on my phone app without contacting the electric coop
I liked when ours quit. Free electricity for a few months before they got around to replacing it. Got to the point I wondered how long they would let it go.
   / Do smart electric meters alert the power company when it's removed? #13
I didn't get any free electricity. It didn't quit metering, it just didn't have a display.
   / Do smart electric meters alert the power company when it's removed? #14
A lot more involved in that around here.
Couple years ago the power corp installed a smart meter. Usually it's a plug and play the meter installer does. Well in mine the block was cracked that the meter plugs into so they had to replace that. Power corp lineman had to come out and disconnect the service at the mast, then they had to call a private company electrician to replace the meter base, once the meter base was replaced they had to call the power corp inspector to inspect the panel that wasn't even touched inside the house. Then they had to call the lineman back to reconnect the power and the meter change guy had to install the new meter and put his seal on it. It didn't cost me any thing but the power was out from about 9 in the am till 7 or so at night. All this time the poor sob that was the meter installer had to hang around with his finger up his backside. I felt sorry for him so I'd go and grab him a coffee and a sandwich.
Major crap if you remove your meter and the tag is cut, they know immediately if the meter is pulled.
Mind you they have more serious issues to deal with now as their (NS Power) customer base got hacked and their customers information was leaked including SIN numbers, passwords, and all other info. My power bill is almost a month late arriving. The way they are going after the rate payers for everything I imagine we'll end up paying somehow.
Nova Scotia Power was the victim of a ransomware attack where hackers stole customer data, including personal information like names, addresses, and financial details. The stolen data has been published on the dark web. The company has confirmed the attack and is working with cybersecurity experts to investigate and restore systems. They are also offering credit monitoring services to affected customer
   / Do smart electric meters alert the power company when it's removed? #15
Way more strict here in idaho and washington state. Im an electrician and a buddy of mine, also an electrician, removed a meter on a fire damaged house to replace service. He didnt bother calling to have it removed. He was arrested for theft of a public utility or something like that. Boss had to bail him out. The meter and all wiring from it to pole outwards is owned by the utility company. If you cut that tab, and pull meter and someone gets hurt, they dont want the liability.
What we HAVE to do is pull a permit (online), than call utility company with permit numer and schedule a shutdown. They pull meter and either blank off the push plates or kill the transformer if were replacing entire panel. They will repower after were done. No charge. This is what i have always done.
   / Do smart electric meters alert the power company when it's removed? #16
And yes, smart meter if pulled, alerts system of a problem. It believes power was dropped to it and our power providers dispatch service crew.
   / Do smart electric meters alert the power company when it's removed? #17
Isn't there a disconnect fuse right next to the condenser where you pull it out for a positive on/off?
   / Do smart electric meters alert the power company when it's removed? #18
Yes, but sometimes the whole disconnect box needs replacing because the pull out contacts are welded or the box is rusted away or it's a new install.
   / Do smart electric meters alert the power company when it's removed? #19
Some of that is going to vary by jurisdiction. In my town no permits are required for anything other than septic (state requirement). No building permits of any type.
I upgraded my service when I first bought this house. After verifying that no permits were required, the electric company provided me with a meter socket, which I wired to my new panel. Then called the electric company and they did the rest...new wiring from the pole & installed the meter. Obviously, there'll be more red tape if your town requires an electrical permit and/or a licensed electrician to do the work (I'm not).
   / Do smart electric meters alert the power company when it's removed? #20
Interesting… when I install a service upgrade the box and rigid conduit up to the weatherhead and the conductors inside are owner supplied in my PGE territory.
I’ve called in to report electric theft and nothing happened for months… the residents going through eviction by passed the meter with speaker wire and duct tape…
The utility said it would wait until the occupants were removed…
It’s not unusual to see utility workers with off duty Oakland Police in full uniform providing security… with department approval… too many utility workers robbed at gun point so this is the solution.
2015 Nissan Pathfinder 4WD SUV (A56859)
2015 Nissan...
John Deere 5103 (A53317)
John Deere 5103...
PALLET TOTE OF MISC (A58374)
PALLET TOTE OF...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
Enclosed Service Truck (A55788)
Enclosed Service...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
