Do severely overheated brake rotors need replaced?
   / Do severely overheated brake rotors need replaced? #1
4570Man
Super Star Member
Crossville, TN
Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
I bought an older kodiak dump truck that needs a little TLC. When I was driving it home one of the back brakes calipers ( this truck has disk brakes ) stuck and it severely overheated the rotor. As in it was glowing. Assuming it isn’t warped does it need replaced? The cost isn’t significant but due to being Dayton hubs on the truck replacing the rotor is a pretty big job.
   / Do severely overheated brake rotors need replaced? #2
It probably will be warped. Probably cheaper to replace than having it ground true. Either way you have to remove it from the truck. When they turn blue I replace them anyway just to be SAFE. There could be microscopic cracks. Use either dye penetrant or magnaflux process to find them. A good machine shop will do that before grinding. The disc pads will get glazed with that much heat. Plan on replacement. Check the hydraulics also boiling brake fluid does strange things like ruining rubber goods.
Ron
It’s getting brake pads on that wheel for sure and probably all the way around. I’ll also probably replace that caliper. I guess once I get that wheel freed up tomorrow I’ll check for warpage. If I end up taking it off I’m tossing it.
   / Do severely overheated brake rotors need replaced? #4
At best it need's to be stone ground because of heat spots. Considering that cost,replacement s best course.
   / Do severely overheated brake rotors need replaced? #5
New brakes on any used vehicle are cheap insurance - liability wise.
Even if it's a close call...... replace
   / Do severely overheated brake rotors need replaced? #6
I would plan on replacing that disk. If it's not warped or cracked, it will at least have hard spots on it. It will probably chatter too. Maybe there's enough disk surface left you could have it turned to clean it up, but I doubt it. Either way it has to come off.
Such is the risk you take when buying old equipment.
   / Do severely overheated brake rotors need replaced? #7
:thumbsup: Its not just your life you are putting on the line here.
   / Do severely overheated brake rotors need replaced? #8
I can only relate an experience I had last year on my BMW R1200 GSA motorcycle. It has disk brakes - front & rear. For unexplained reasons the pads began dragging on the rotor on the rear wheel. Took it back in to the BMW dealer for their appraisal.
One quick look and their answer - replace the rotor, caliper & pads. I don't think the rotor ever got red hot but - WoW! - it was hotter than you wanted to touch. The rotor had turned black - as black as black can be. Even with the pads dragging lightly - the "black" was never scrubbed off the rotor surface.
Anyhow - 2500 miles later and no further problems.
Their answer - "makes no difference. With a situation such as I had - we will not risk repair. Any of the components could be structurally or mechanically damaged and a failure could lead to a serious accident".
Recognizing - a rear wheel lock up on a motorcycle can be a lot more serious than on a four wheel vehicle.
   / Do severely overheated brake rotors need replaced? #9
Sounds like you're on the right path 4570. Like you mentioned, it's probably started with the caliper and if not, the heat would have wrecked it anyway.
When you bleed the brakes, I'd flush all of the fluid out too. Also check the hoses, as they do break down and act as one way valves.
I put calipers and brake pads on both sides. It required a 3.5” thin wall socket to take the hubs off and I didn’t have one so I didn’t change the rotors. They looked pretty good anyway so I left them alone.
(INOP) TAKEUCHI TL12R2 SKID STEER (A51242)
(INOP) TAKEUCHI...
Skidloader Bucket W/Hydraulic Attachment (A50774)
Skidloader Bucket...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
2007 WESTERN STAR 4900 (A52472)
2007 WESTERN STAR...
AMG M 35A2C drop side 2 1/2 ton 6 x 6 (A50323)
AMG M 35A2C drop...
