Do I really need loader float if I have a box blade/rear blade?
   / Do I really need loader float if I have a box blade/rear blade? #1
BadDecisions
Wittmann, AZ
Ford 8N
Old Wagner WM-3 loader on an 8N. Before anyone says it, yes, I'm aware that loader on Ford *N is bad. I've already had this tractor and loader for years, and I rarely use the loader. 99.9% of the time, I used it as a crude crane, and I don't even do that any more since I put an actual crane on my utility truck. Rare enough that it doesn't make sense for me to go buy another tractor for the once every few years I need the loader, and it's simple to install/remove the loader with the crane, so it's only on the tractor when I need it.
A project has come up that I need the loader for...last time I used it, all 3 cylinders were leaking, and it wasn't holding height...so I'm rebuilding the whole dang thing. I see replacement control valves are available with and without float, which I understand make so the loader has neither up or down pressure on it for things like dragging the bucket to grade with it.
I already have a large back blade and box blade that I use for those things, and I THINK the Wagners floated naturally even without a specific float position. The few times I tried back dragging the bucket, it seemed like it would just bounce over the ground, but it's been years since I tried that. I quickly decided the rear blades worked far better than the bucket for grading.
All that said, is there some other reason I should consider getting a float capable control valve?
Giyi 59" Mini Stump Grinder (A53316)
Giyi 59" Mini...
Schumacher Jump Box (A54865)
Schumacher Jump...
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
40' CONTAINER (A51244)
Wright Self Dumping Hopper (A55787)
Wright Self...
Giyi 44" Mini Grapple (A53316)
Giyi 44" Mini...
