Do I need the 37 or 55? Thoughts?
   / Do I need the 37 or 55? Thoughts? #1
Rmally
Bronze Member
East Tennessee
RK 55 Hydro
Would love to hear some opinions on which I REALLY need......the 37 or 55.
The primary use of the tractor will be for maintaining my 1900 feet long gravel driveway, mowing down the hay fields if they don't get cut and moving some odds and ends and occasionally a round bail.
I have 21 acres, non wooded with some slope but not what I would call steep. I was at RK today to compare again and watched 12-13 Morgan videos yesterday but still undecided. I have never owned a tractor before and this is my first land purchase. We will have a barn and a few horses.
Usually the hay gets cut by the neighbor but sometimes he doesn't show and I'll need to cut it. Not much brush just 3-4 feet tall grass. Do I need 55hp or will 37 be enough? Will the 37 with (I think) 29 PTO hp be enough to box blade the driveway and cut the fields?
I know you should always get bigger just wanted input on what y'all think who actually own these tractors. I will be getting the hydrostatic, 4wd with cab. Would love to save the $5,500 but if you think the 37 is going to be struggling let me know. On the other hand if the 37 is plenty would like to know that as well.
Thanks in advance.
   / Do I need the 37 or 55? Thoughts? #2
Pto hp won't impact your bb use. That said, based on what you said your needs are, I think I'd save the 5500 dollars.
   / Do I need the 37 or 55? Thoughts? #3
I have the 55, but if I was only cutting 21 acres infrequently I think the 37 would do ok. That's the only thing we do here that really use all the power the tractor will put out.
   / Do I need the 37 or 55? Thoughts? #4
Not familiar with Rk but hydro and air conditioning will rob some power;I would go with the higher HP tractor.I have a cabbed 44 h.p.and it does all I need year round;rarely use low range.
Thanks for the input fellas.
   / Do I need the 37 or 55? Thoughts? #7
Get the 55 or in a year or two you’ll be trading in for more tractor. That’s just the way it works, you will find more things to do with it including bigger jobs.
   / Do I need the 37 or 55? Thoughts? #8
Yep, go 55. You will want the extra PTO HP when bush hogging when the time comes. If you can afford it, the extra money will be long forgotten when you aren't cursing yourself for not being able to get a bigger rotary cutter after you get tired of using a 5-6 ft'r.
   / Do I need the 37 or 55? Thoughts? #9
I went with the RK55 vs the 37 specifically for the ability to run a 7 ft mower. Yes, the 37 could run that size mower, but in knee high grass, I think it would struggle, at least my 32 hp Massey did and that was using a 5 ft mower.
If this is a tractor you plan on having for the long term, and you’re not dealing with tight spaces where maneuverability is a concern, I’d go with the RK55. You never know what situations will arise down the road. Maybe something happens to your hay field helper. Plus, as of right now, the 55 has one option the 37 doesn’t - the telescoping 3 pt arms. Very convenient when switching implements.
   / Do I need the 37 or 55? Thoughts? #10
My 37H came with the telescoping arms.
2006 Ford F-250 4x4 Ext. Cab Pickup Truck (A48081)
2006 Ford F-250...
2013 FORD F-450 UTILITY TRUCK (A51222)
2013 FORD F-450...
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
UNUSED Bubble Aluminum Foil Reflective Insulation (A50860)
UNUSED Bubble...
1973 POWER 30ft Pole S/A Towable Trailer (A48081)
1973 POWER 30ft...
