do I need a pressure relief?
/ do I need a pressure relief? #1
memphismark
california
Bobcat
Hi Guys.
I'm driving a 8-14 GPM auger gearmotor with a 22 hp gas engine spinning a Prince .75 cubic pump, and everything is operated with a Prince 20 GPM motor spool valve. The spool has a relief pressure set at 2800 PSI, and forward between the spool and the auger motor is a Prince cushion valve (also set at around 2800 PSI). My question is, do I need a relief valve on the other side or pump side of the spool valve? It would seem the spool relief would handle that side too. No? Yes? Maybe?
Would appreciate some sage advice. I'm a learning novice at hydraulics, not totally dumb, but a somewhat elementary explanation would help. Thanks in advance guys. memphismark
/ do I need a pressure relief? #2
Your valve relief is on the pump side or IN port side of the valve.
It is there to protect the pump.
2013 CORPUS 40FT  T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
2000 FORD F-650 SUPER DUTY (A63569)
2000 FORD F-650...
John Deere 1023E (A62177)
John Deere 1023E...
Skid Steer Mounted Bush Hog (A62613)
Skid Steer Mounted...
60 Traffic Cones (A65579)
60 Traffic Cones...
Buckhorn Poly Feed Box (A66408)
Buckhorn Poly Feed...
