do I need a pressure relief?
/ do I need a pressure relief? #1
memphismark
Bronze Member
california
Bobcat
Hi Guys.
I'm driving a 8-14 GPM auger gearmotor with a 22 hp gas engine spinning a Prince .75 cubic pump, and everything is operated with a Prince 20 GPM motor spool valve. The spool has a relief pressure set at 2800 PSI, and forward between the spool and the auger motor is a Prince cushion valve (also set at around 2800 PSI). My question is, do I need a relief valve on the other side or pump side of the spool valve? It would seem the spool relief would handle that side too. No? Yes? Maybe?
Would appreciate some sage advice. I'm a learning novice at hydraulics, not totally dumb, but a somewhat elementary explanation would help. Thanks in advance guys. memphismark
/ do I need a pressure relief? #2
Your valve relief is on the pump side or IN port side of the valve.
It is there to protect the pump.
Duratech HD 8 Tub Grinder (A62613)
Duratech HD 8 Tub...
96" X 20' TRI-AXLE TRAILER (A64280)
96" X 20' TRI-AXLE...
Informational Lot - Financing (A63688)
Informational Lot...
Bell 1600 Gallon Nurse Trailer (A63688)
Bell 1600 Gallon...
2007 Freightliner FLD120 (A62679)
2007 Freightliner...
2018 Dodge 5500 Bucket Truck 4WD (A63689)
2018 Dodge 5500...
