Do I need a block heater for a BX24???
   / Do I need a block heater for a BX24??? #12
They are talking about a 3030 and I think there is something wrong with a heater plugged in for four hours and he cannot feel warmth on the engne. My oil pan is HOT after an hour.
Further on the subject, it is still important to follow proper warm up procedure as per the manual for the hydro-oil.:D Good winter fuel and keeo a jug of Powersave 911 just in case of jelling.
   / Do I need a block heater for a BX24??? #13
Mswlogo,
Do you NEED a block heater, NO, hold the glow plug for 10-15 secs and it will start as others have said. Will you like the way it sounds and acts when it starts, NO. Most of the engine wear is occurring in the 1st few seconds until the oil starts to do its thing. If the engine has sat for a few weeks without use, the oil has drained back and the pump has to do its thing even more.
I plug my heater in for 1 hour before starting and the engine is warm to the touch in an unheated shed. (I actually installed a 1 hour timer on the wire to the outside receptacle that I plug the extension cord into and yes it is 12 gauge cord, and just turn the knob and an hour latter I am good to go.) I also use synthetic oil too, I consider the oil and the block heater sleep insurance. My dealer said the same no need to install a block heater, BUT I did it anyway, it is my tractor I can do what I want with it and so can you:D
   / Do I need a block heater for a BX24??? #14
I have a block heater - in the box for my BX24 - never installed it... I suppose I could plug it in and make the box warm...
   / Do I need a block heater for a BX24??? #15
NY_Yankees_Fan said:
Mswlogo,
Do you really think the Synthetic oil will flow and protect the engine that much better just because you preheated it?
My car doesn't have a block heater or my snow blower. It only takes over night for oil to drain and get as cold as something sitting a couple weeks.
I try not to fall into habits of, Hey it doesn't hurt, it's iunsurance, because I can do it I will. When it *might* be perfectly fine with out it. I'm not saying you should or should not. I'm just not convinced it will extend it's life.
Many people think you should change your oil in your car every 3000 miles. Which is excessive and wasteful. I Change (with synthetic) every 10,000 miles. Never had a problem in 5 cars all well over a 100k and don't burn oil (other than normal amount about 1 qt in 10k miles). Cars are outside most of the time. I also see people warm up their cars for 20 minutes, also a waste. I'm trying to be more green in my life and questioning ANYTHING that uses resources.
Block heaters were invented to help diesels START in exstreme conditions. Now they are being recommended for keeping it warm and cozy, so the owner sleeps better.
I'm not saying I won't put one on. But I'm not convinced it's really doing anything. I don't care if it runs rough for a few minutes. As long as the engine is not being damaged because of it. Maybe since it needs less warm up it will actually save in net resources. I don't know.
   / Do I need a block heater for a BX24??? #16
I can remember as a kid my father digging a small hole and draining the oil out of his car into it when he changed the oil. His father taught him that, after all oil comes from the ground so it should be OK putting it back into the ground. How life has changed. The reason 3k miles for normal oil is the accepted lenth of time is because after that time frame it looses enough of it's lubricating properties that it will start waisting more gas or diesel. Synthetic clearly can run longer, how much I really don't know so I follow what's recomended.
Warm oil will flow much easier for the first few moments when you start a motor up so it stands to reason it will be better for the engine. Like someone else said nothing else will be warm though. If you have the time I would use one, you're not going to hurt it by using one. You may even get more life out of your starter.
   / Do I need a block heater for a BX24??? #17
'Green' has to be one of the most overused words there is in today's vocabulary. What does it mean? Green is always good? Bile is green...who wants a big tumbler full? People are said to be green with envy. Is that now a good thing? I am not picking on you; it's just that I can't pick up a newspaper without that word being in the title of a half dozen articles and I'm sick of it. That and the word 'hoops' being used to describe the game of basketball. Rant over, no offense intended, if some was taken, I apologize in advance.
Now, I don't have any scientific data to back this up, but I am going to propose that when you cold-start your diesel and it is emitting white smoke until it warms up.....that you have more than offset the amount of stack-scrubbed, coal-fired power plant generated electricity it would have taken a little block heater to warm your engine to the point that it didn't do that. That white smoke is unburned hydrocarbon fuel...not too Green, you know. Cold starts are probably the primary source of fuel in the oil. And fuel in the oil makes you change it sooner, thus being less (everybody say it with me) Green.
   / Do I need a block heater for a BX24??? #18
3000 is excessive for dino oil too, it maybe made sense in the 40's. In the 70's well before the synthetics, while all the americans were told to change it at 3000 by manufacturer they were told 5000 in europe, on the SAME EXACT CAR !!!
   / Do I need a block heater for a BX24??? #20
I live in Northern Ontario and keep my B7800 in my unheated garage beside. Winters here are usually -10C to - 20C but it does go down to -32C a few times each winter
I have a block heater on the B7800 and have it on the same timer (set at 2 hours) as my wife's car. I work from home so my truck isn't plugged in usually.
The block heater in both the tractor and the car make a huge difference in how fast they warm up and are ready to drive.
I think one of these would work well on a tractor
Tractor Supply Company - MAGNETIC HEATER
2008 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2008 CATERPILLAR...
1975 Dodge 600 Grain Truck (A50514)
1975 Dodge 600...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51242)
2020 KOMATSU...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A52128)
2003 International...
2018 Volkswagen Jetta Sedan (A50324)
2018 Volkswagen...
2004 Caterpillar 345B Hydraulic Excavator (A50322)
2004 Caterpillar...
