Do BXes ever NOT break? Steering hoses AGAIN
   / Do BXes ever NOT break? Steering hoses AGAIN #11
Do BX's never NOT break?
2004 BX23 just clocked 1000 hr's on the same hoses that came on it. So far no leakie (knock on wood)..
I did have to replace the right steering knuckle seal at 900 hrs but based on the dirt and rocks that collected around it I'd say better cleaning after a hard workout in the dirt may have prevented that.....
   / Do BXes ever NOT break? Steering hoses AGAIN #12
The same year I bought my used BX2200, I had the classic 600 hour rear steering hose leak (at 630 hours). I changed the two rear hoses. It's been about another 30 hours and two years, and I just blew steering hoses again. I'm pretty sure that it's the fronts this time, at least based on the hydraulic oil that is spewed all over the front of the machine. What's with these lines and why do they fail? The circuit isn't even a high-pressure circuit. I've never seen or heard of such a thing. At least it appears that the front hoses will be easy to change, unlike the rear ones which was a PITA.
Do you keep your machine indoors or out? I've read the sun is brutal on the hoses. Also... 600 hours is not new...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
LOT: Air Hose Reels, 220 V Cord, Electrical Cords, Hand Tools, 2-Wheel Hand Truck (A59076)
LOT: Air Hose...
2016 Ram 3500 Crew Cab Chipper Truck (A55973)
2016 Ram 3500 Crew...
2016 SHADOW CRUISER (A58214)
2016 SHADOW...
CASE INTERNATIONAL 3950 - 21' DISC HARROW (A52708)
CASE INTERNATIONAL...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
