Do BX users think this will work
/ Do BX users think this will work #1
Tractor_Jim_CT
Connecticut
BX23
I have a small JD tractor with a plow that I use, but would like to use the FEL to help push or move heavy snow in addtion. I've read how some have protected the bottom of the FEL with a strip of horse mat. I came across these skids that appear can fit in the bottom of the FEL. See link below.
Thoughts on will these fit the bottom of the FEL and work. They appear they may be a solution to keeping the FEL off the ground enough to do the job. If so, what method have users used to drill the holes on the bottom of the FEL to attach Horse mat or these skids for that matter. All thoughts welcomed. Thanks - Jim
Warn Utility Plow Replacement Skids
The Plow Replacement Skids keep your plow from digging into gravel roads or other soft surfaces for smoother operation. Also protects your blade by lifting it slightly above plowing surface. Sold per pair. /forums/images/graemlins/shocked.gif
http://www.cabelas.com/cabelas/en/templates/links/link.jhtml;jsessionid=RLEAP5XCBBLDLTQSNOISCNOOCJVZIIWE?id=0013291520889a&type=product&cmCat=static_product&_requestid=6612
/ Do BX users think this will work #2
IIRC, the guys bolting horse mat are putting in on a cutting edge of a snow blade, not the bottom of the FEL.
To answer your question, yes, I'm sure you could mount these parts on the bottom of your FEL. Just don't try drilling through the cutting edge of your blade, like I tried this weekend. It is TOUGH steel!
If you put horse mat on the bottom side of your FEL, I'd think it would wear or tear off quickly if you run it on gravel or concrete.
Last winter, I simply bolted a 48" piece of 2x12 on the front of the FEL lip. This worked to slide along the concrete without catching and I could back drag with it.
I built this dozer blade and might put a board or horse mat on it for winter. We don't get that much snow, so it would work ok. Couldn't use the loader bucket to move snow and dump it, but not an issue for me.
Enjoy.
Ron
/ Do BX users think this will work #3
They are pretty wimpy looking to me and I think that they wouldn't really work well on the loader. They are designed for light weight ATV snow plows. Also, they will not help keep the bucket up unless the ground is frozen. On un frozen ground, they will just dig into the ground.
/ Do BX users think this will work #4
No matter what you attach to the front of your FEL, you still have the problem of pushing snow straight ahead such that it gathers and eventually exceeds your traction capability. You have mentioned using it to help push "heavy" snow. This might work for a while if you have a very large tractor but what you really need is a way to angle the front so the snow dumps off.
How about an old grader blade mounted offset to the bucket or a system like my attached pic.
Thanks SeymourBota. Does the setup move manually?
I'm surprised a plow designed that attaches like yours to the FEL is not available for those who don't want to remove the FEL. I have a angle manual blade on the JD..just looking for a way to move snow only for the BX23 with a simple or no change to the FEL/BH setup. Since I've never removed these two attachments yet, maybe it's just anxiety.
/ Do BX users think this will work #6
I would think that setup would put a lot of side stress on the loader arms while pushing snow with it angled sharply. To mount my plow (Kubota) you remove the FEL and mount a quick hitch to the front of the tractor. The plow then mounts to that. More work taking everything on & off, but no stress on the loader. Disadvantage: it can be raised, lowered and angle left & right, but not tilt forward or back like yours could.
/ Do BX users think this will work #7
My personal experience has been that the FEL is only good for piling the snow that you have plowed with something else. It really sucks for snow removal.
Try a back blade rotated so the it is convex rather than concave on the leading edge. That way it won't dig in.
I didn't even like that, although it was alot better, so I use an ATV mounted blade, and when the edges get too big, I use the FEL to pile it somewhere else.
Perhaps it won't even snow this year....
/forums/images/graemlins/ooo.gif
Ken..When you get yours setup later this year, (fiqure it's to early yet) would you be able to post a picture or if anyone has in the past.. Curious on brand of blade, etc along with costs for the whole setup with the quick attach. I take it the bucket is removed??? Thanks
/ Do BX users think this will work #9
I also have one of these power angle blades from Curtis, which replace the bucket on the loader arms:
http://www.curtisintl.com/tractor_loader.html
This is more of a project, in terms of removal and installation, however.
I installed extra steel plates on the top and bottom of the bucket surface in the setup I posted the pic of, to distribute stress. This is used strictly for smaller snowfalls- there's a 60" 3PH snowblower on the rear for winter.
The best thing is that if I really want to use the bucket, I just pull one pin, back away and I'm in business!!
/ Do BX users think this will work #10
Tractor Jim CT- yes, I can manually angle the blade left, right or center (there are only 3 positions).
I contemplated trying to rig up my 6 ft 3PH blade to the bucket with some type of offset, but the challenge included the question of how to accomodate hitting an obstacle, since the 3PH blade is not spring-loaded.
/ Do BX users think this will work #11
I don't believe that there is a way presently available to mount a Quick Disconnect plow to the loader arms of a BX tractor. considering the weight limitations of the BX, I doubt that it would be commercially viable to manufacture Quick Disconnect appliances to replace the loader bucket such as those that are available to the larger tractors such as the L48. The best solution that I think that is available is the Kubota Quick Disconnect front mount hitch as used with the Snow Plow, Snowblower, Sweeper. This requires the removal of the loader bucket and the front grille guard to install the Quick Disconnect. Just like you won't find the amenities of a Cadillac class car on a Chevette, you won't find they variety of options for a BX as you would the L48 class of tractors.
The best suggestion that I can make for using the loader bucket along with a snow plow is to purchase a 54" or 60" garden tractor snow blade and then weld "ears" onto the bottom of the bucket to hold the plow hitch frame in the bucket. This will allow you to remove it when you don't need it and install it quickly when you do. I have seen this done many times with larger tractors. Just remember that the BX does have its limitations as to how much snow that it can push, even in 4 wheel drive. I refer to the BX as the "Bulldog Xperience" tractor because of the similarity to the Bulldog, however, it isn't ever going to be a Great Pyrenees, no matter how hard we try.
/ Do BX users think this will work #12
What it would look like on the bucket side ....... you would need to weld in some "ears" to hold the "A" frame in the bucket. This is a Bolens HT20/23 54" snow blade left over from when I used the Bolens to plow snow. It is headed onto e Bay with some other of my Bolens items. Since buying the Kubota BX, I haven't sat in the Bolens except to move it out of the garage.
/ Do BX users think this will work #13
I've installed a 3PH blade to my loader arms and was also worried about hitting something and bending my loader arms. I tried to be as cautious as I could be, but last week, I hit a protruding pin beside my driveway while ploughing the snow. It stopped me quick, and luckily no damage this time. Here's a picture of my set up. I've posted this on another thread earlier. I've used the bucket cylinder to angle my blade, and put in a fixed link to replace the bucket cylinder's original location.
/ Do BX users think this will work #14
I was trying to find a way to attach it inside the bucket- never thought of doing it the way you did, but your way is very ingenious.
My Snowsport plow has a very thick rubber edge on the bottom that it replaceable. Something like that might make a spring assembly unnecessary.
/ Do BX users think this will work #15
SeymourBota,
The pic you posted shows a simple 2" hitch mount. Is this a plow designed for a small pickup? Looks like a good idea for light snows, susch as we get here south of Richmond, VA.
Thanks,
Dave in VA
/ Do BX users think this will work #16
Yes, it is designed for a 2" receiver hitch. I have one on the front of my pickup, but you can also install the blade in the rear hitch that most have and then plow in reverse!!
http://www.mysnowsport.com/
/ Do BX users think this will work #17
I had them skids on my ATV. They only lasted one season so every year I had to buy new. That was my ATV not a heavy bucket. My bucket has a skid plate on it and it can be replaced. So I will just let my bucket on the concrete and the way I figure it I will get 5 years out of my skid plate and then just pay my friend to replace.
murph
A SKID PLATE-Can anyone enlighten me on the skid plate idea and any photos would be cool. I will probably continue using my John Deere Mower with the front blade, rear tire chains and weights again this season. I have a long
asphalt driveway and thought I bought this BX23 and there must be a way use the bucket also during the winter.
The plow has skids and I thought skids on the bucket bottom is all thats really needed. Just curious how a skid plate was made or bought and mounted.
Just trying to make more use of the BX23.
/ Do BX users think this will work #19
I use my loader and bucket to remove snow, but I have a short paved driveway. It works fine in float position with no skid plate at this time.
One idea for a skid plate that someone had was to use a section of the new composite deck boards bolted to the bottom of the bucket (a 12' would give you 3 wear plates and would keep your drive in good shape). I think that it is a great idea, but haven't implemented it yet.
Just another thought.
MASSEY FERGUSON 2605 TRACTOR (A62130)
MASSEY FERGUSON...
karcher pressure washer (A61567)
karcher pressure...
2019 FREIGHTLINER M2 4X2 S/A NON 26FT NON CDL BOX TRUCK (A59914)
2019 FREIGHTLINER...
KBH Cotton Spear (A64126)
KBH Cotton Spear...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
