Do any 3 pt hitches provide downforce?
   / Do any 3 pt hitches provide downforce? #31
All 3 of my 3-pt's have down pressure. ---I wouldnt own one that didn't!
   / Do any 3 pt hitches provide downforce? #32
Do you have to put it in float manually every time you lower it?
I’d probably forget 1/2 the time and wreck every attachment when I went through a dip and tried to support the weight of the tractor on the attachment’s brackets.
or forget to be in 4 wheel drive so I would sit there with the back wheels spinning off the ground.
   / Do any 3 pt hitches provide downforce? #33
I just wish mine would drive itself down while empty so I didn't have to put a foot on one of the arms.
OK. Dumb question I guess, but I gotta ask. Are you on the tractor when you do this, or off it?
   / Do any 3 pt hitches provide downforce? #35
May I ask what brand/model tractors you have that have down pressure on 3 pt hitch?
Thanks,Jim
   / Do any 3 pt hitches provide downforce? #36
Just turn that knob between your legs and it will speed up.
   / Do any 3 pt hitches provide downforce? #37
International 300 Utility has positive down pressure. Nice for blade, post hole digger or if you want to sit the brushhog down on some stubborn trees.
   / Do any 3 pt hitches provide downforce? #38
all my belarus' have down force, about a 3 inch cylinder on the three point, maybe 8,000 pounds down force ?? it will lift the back of the tractor off the ground ...
i use two tractors , in just the two positions, basically the 'up' position, and the 'float' position for three point mowers .. i never have used the 'position' mode, or any others [the finish mower has four wheels, and the rough cut [woods] doesn't have any ..
   / Do any 3 pt hitches provide downforce? #40
lotsa farmalls do
2018 Dodge Charger Sedan (A55853)
2018 Dodge Charger...
2013 Dodge Durango Crew AWD SUV (A55853)
2013 Dodge Durango...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2014 Cadillac ATS Sedan (A55853)
2014 Cadillac ATS...
2013 Ford F-750 Pak-Mor 16 CuYd Rear Loader Garbage Truck (A56858)
2013 Ford F-750...
