JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 3,809
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
DL250 loader mounted on an MF2660HD low Profile tractor. The machine has about 90 hrs on it, though I've had it since April 2011. In all that time I noticed the bucket could not be "forced tip down" to do things like smoothing soil or sand or gravel in reverse. It curls up fine but only rolls downward via gravity -- you cannot force the tip down. This is with the loader frame stationary -- not a loader frame issue but rather a bucket control issue. Yes, the loader will lift the tractor (but not using bucket down roll. It just goes limp.) I thought it was a disease of this brand at first (my older John Deere would easily lift the tractor with down roll after I'd had it 10 years) but now everyone agrees this Massey is not right.
It is as if there was a "float" function in the bucket roll axis sort of -- roll up works, roll down does not. One dealer says the loader valve body is the problem. Another dealer says the O-rings are bad in one of the two long cylinders that roll the bucket (top front cylinders on the loader.) Note that both those cylinders are fed pressure from a "T" so a failed O-ring allowing constant bypass in either of the two cylinders would make both of them useless. Keep in mind this is nearly a brand new machine and none of this stuff has any significant wear on it.
What say you ?
What say you ?
