DL 120 Massey Ferguson
   / DL 120 Massey Ferguson #1
Ajculp
Prescott ar
Massey Ferguson 1533
My bucket was dumping fine then I picked up another load of dirt and it want dump. It tries but the hydraulics will only extend about an inch pulled bucket off still same.
   / DL 120 Massey Ferguson #2
Check your QD.
Do you think one of my disconnects is the cause?
   / DL 120 Massey Ferguson #4
The first part of the post, I understand. The rest of the post I have no idea what is being said.
   / DL 120 Massey Ferguson #5
Seems like he took the bucket off, and the cyl still will not extend.
If a cyl will not move using a good pump and the valve is activated, then the flow is blocked or the cyl is really broke. If he has QD's, that is the most likely cause.
The piston rod nut could have come off, and fluid is just flowing back and forth with no force.
The QD was not seated thank you for the help.
STRICKLAND CASE 621D WHEEL LOADER FORKS (A52705)
STRICKLAND CASE...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
UNUSED 3 STEP - STEP LADDER (A54757)
UNUSED 3 STEP -...
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
Flat bed utility truck with inline 6Cy engine (A55301)
Flat bed utility...
2012 Cadilac SRX SUV (A53424)
2012 Cadilac SRX...
