DK65s Clutch won't return
/ DK65s Clutch won't return #1
belizebound
Southern Missouri
DK65S Kioti
DK65s Clutch won\'t return
Does any know if you can bleed the clutch line like you can the brakes? I have to use my foot to pull the clutch back up till the tractor runs for a hour or so. One of the brakes was soft so I bled the lines and got a little air out and now they are fine.
thanks
b
/ DK65s Clutch won't return #2
Re: DK65s Clutch won\'t return
Yes you can, bleeder screw is under the floor pan. Is your reservoir tank full?
Thanks Jon,
found the bleeder. The fluid was low. Had to buy the Tellus 32 in 5 gal pail so I will have plenty around for awhile. I also found a clutch hold down lever which I never noticed before...
bb
/ DK65s Clutch won't return #4
I would want to find out why the fluid was so low. Check your hoses for any leaks or if a hose is rubbing against something and leaking.
2008 FORD F150 EXTENDED CAB PICKUP TRUCK (A66091)
2008 FORD F150...
2012 COMPTANK  ACID TRANSPORT TRAILER (A67714)
2012 COMPTANK...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2015 SUNDOWNER 25 T/A ENCLOSED TRAILER (A67714)
2015 SUNDOWNER 25...
2011 Kenworth T800 Truck T/A Wet Kit Sleeper Cab Truck Tractor (A64194)
2011 Kenworth T800...
2014 CHEVROLET CAPRICE POLICE CAR (A66091)
2014 CHEVROLET...
