DK55C PTO Trouble
   / DK55C PTO Trouble #1
billr3408
My PTO stopped while I was using it. There is no light on switch on roll bar or instament panel. I've checked the 10amp fuse and PTO relay and both are OK. What is my next option?
Thanks,
Billr3408
   / DK55C PTO Trouble #2
Remove the fuse and use a tester to check it sometimes they blow internally and you cant see it.
   / DK55C PTO Trouble #3
Were you operating in brush when it happened? The PTO on the newer models are electrically controlled and it is possible to either damage or hopefully just unplug one of the connectors under the operator station. I did that (unplug) with my DK40se and lost the 4wd function until I sorted it out and plugged it back in.
Chery 7' 20 Drawer Workbench (A50121)
Chery 7' 20 Drawer...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
P.T 8' Offset Disc Harrow (A50120)
P.T 8' Offset Disc...
John Deere 920 Platform (A50514)
John Deere 920...
KJ Double Ply Polyester Webbing Sling (A50121)
KJ Double Ply...
John Deere 700 Hydraulic Hay Rake - Durable Side Delivery Rake for Efficient Windrowing (A52748)
John Deere 700...
