DK5510 Oil change recommendation
   / DK5510 Oil change recommendation #1
sirrobinhood
Bolingbrook,IL
Kioti DK55
Hello all, I know this is a common question, but manual states 10W-30, 10W40, 15W40.
My farm is in Central IL. The coldest I think I've ever operated the tractor was around 10-15 degrees.
I have used the tractor with temps up to 95 degrees. What oil weight would you recommend?
Thanks
   / DK5510 Oil change recommendation #2
I live in S.Michigan I run 15w40 year around in my Kioti DK40..
   / DK5510 Oil change recommendation #3
I run 15W40 year round in my DK45S I am along the I-70 corridor in IL
   / DK5510 Oil change recommendation #4
I have a DS4110 and I run 5W40 full syn. It makes for easier cold starts, and the 40 weight makes for a heavier film to reduce soot getting past the rings.
   / DK5510 Oil change recommendation #5
Either Rotella 15-40 , or the Rotella T6 full synthetic 5-40 will serve you well.
   / DK5510 Oil change recommendation #6
Rotella T6 5W-40 just for the easy Winter starts when it may be 0F and I don't have a block heater. Also good year round for me when it can be 90F.
   / DK5510 Oil change recommendation #7
^^^ 5w-40 Rotella for the WIN! :D
The low number says what its viscosity is at 0 degrees Fahrenheit: the "W" means "winter," cold range. 40 is the viscosity at 212 degrees Fahrenheit. In general, price not an issue, a lower cold viscosity is always the better one. (up in Canada 0w-40 [or 0w-30] is a lot more common, but, I believe, a fair bit expensive)
   / DK5510 Oil change recommendation #8
Generally speaking, the greater the spread in the multigrade, the more expensive the oil.
I致e used 0wXX痴 before, but generally you don稚 see the benefit until you hit sub-Arctic. The 5wXX痴 flow really nice at -25c, so that痴 good enough for me. Where you really benefit from the 0wXX痴 is with hydraulic oil, which doesn稚 heat up as fast as the motor oil, and can result in some really slow moving implements.
   / DK5510 Oil change recommendation #9
Rotella T-6 5w-40 year round is what I run.
   / DK5510 Oil change recommendation #10
If I had a french fry machine I'd be running T-6 5w-40 in it as well! :laughing: (I'm switching back to it after running 5w-40 Delo LE (which I was getting for pretty cheap from Walmart); seems Chevron is changing their oils and right now 5w-40 isn't readily available; probably end up sticking with Shell now).
2013 Ford F-150 Pickup Truck (A56858)
2013 Ford F-150...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
2013 COACHMEN CATALINA TRAVEL TRAILER (A58214)
2013 COACHMEN...
2004 Ranger 195VX Comanchee Bass Boat with Trailer (A57453)
2004 Ranger 195VX...
Rockland EB35 42inch Tooth Excavator Bucket (A59213)
Rockland EB35...
