DK55 Work Light
   / DK55 Work Light #1
DrFred
Upstate, SC
Looking at present
The rear work light on my DK55 does not work and I can't figure out why. The switch is good, the contacts are getting good voltage, and they ground shows continuity. The bulb is good, although I tried to replace it just in case. I have tried everything. Any thoughts or has anyone else had this problem? Thanks
   / DK55 Work Light #2
Make sure contact is being made on the bulb. Old auto trick
   / DK55 Work Light #4
I bet the actual contact points are corroded just enough. Try cleaning the socket out with a small pic and then some Dielectric grease on the bulb contacts.
   / DK55 Work Light #5
Just scrape the contact points with the point of a test light. Then you can check to make sure your getting power there at the same time.
2011 Mack CXU613 Truck (A52128)
2011 Mack CXU613...
2014 Ford E-350 Cargo Van (A50323)
2014 Ford E-350...
John Deere 825i Gator (A50514)
John Deere 825i...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2013 Hyundai Sonata (A50324)
2013 Hyundai...
