DK55 Work Light
/ DK55 Work Light #1
DrFred
Upstate, SC
Looking at present
The rear work light on my DK55 does not work and I can't figure out why. The switch is good, the contacts are getting good voltage, and they ground shows continuity. The bulb is good, although I tried to replace it just in case. I have tried everything. Any thoughts or has anyone else had this problem? Thanks
/ DK55 Work Light #2
Make sure contact is being made on the bulb. Old auto trick
/ DK55 Work Light #4
I bet the actual contact points are corroded just enough. Try cleaning the socket out with a small pic and then some Dielectric grease on the bulb contacts.
/ DK55 Work Light #5
Just scrape the contact points with the point of a test light. Then you can check to make sure your getting power there at the same time.
2021 CATERPILLAR 299D3 XE SKID STEER (A65053)
2021 CATERPILLAR...
2022 EZ-GO ELITE...
2007 30ft. Regal 30 Express Cruiser Boat with 2010 Vantage T/A 33 Ft. Trailer (A64557)
2007 30ft. Regal...
2005 JOHN DEERE 4110 TRACTOR (A65054)
2005 JOHN DEERE...
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
2006 Peterbilt 379 T/A Sleeper Cab Truck Tractor (A64194)
2006 Peterbilt 379...
