Oil & Fuel DK55 losing motor oil, gaining hydraulic oil...
   / DK55 losing motor oil, gaining hydraulic oil... #1
jeepking1
Independence, MO
Kioti DK55
New to forum, and this my first post. My girlfriends dad has a Kioti DK55, and he has noticed that he is losing engine oil, and gaining transmission/hydraulic oil.
There are no external leaks, and the engine doesn't smoke. The exhaust is clean and not blowing oil residue. He has a loader on the front with a bale spear, and a bale spear on the back. This tractor gets used mainly for moving round bales.
He has not pulled the clutch housing drain bolt yet, but the clutch seems to be working fine, so we dont think the oil is travelling through that area. We have been racking our brains and can't think of any way that motor oil could get transferred into the transmission area.
My only thought was that maybe somehow, an engine gear driven hydraulic pump might be sucking motor oil past a seal and mixing it into the hydraulic oil side?
Any help or ideas would be greatly appreciated.
Thanks, JP
   / DK55 losing motor oil, gaining hydraulic oil... #2
:welcome:
   / DK55 losing motor oil, gaining hydraulic oil... #3
Has to be a leak between pump and engine
   / DK55 losing motor oil, gaining hydraulic oil... #4
Have you tried a search through this forum yet? I seem to remember a DK55 with similar issues.
I haven't had much time to research yet, but I did find one that was making motor oil instead of losing it.
   / DK55 losing motor oil, gaining hydraulic oil... #6
Losing motor oil, gaining hydraulic oil, most of the time it's the other way around. I guess it could happen because of the hyd. pump, the seal isn't to hard to change and a good place to start.
It's a head scratcher for sure. We can't think of any other place where that kind of fluid transfer could happen.
2006 TerraGator 8104 (A53472)
2006 TerraGator...
UNUSED JCT 72" HYD TILLER (A51248)
UNUSED JCT 72" HYD...
UNUSED FUTURE GR87 87" ANGLE GRADER BLADE (A51248)
UNUSED FUTURE GR87...
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
2021 John Deere 310SL Backhoe (A53342)
2021 John Deere...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
