Oil & Fuel DK55 losing motor oil, gaining hydraulic oil...
   / DK55 losing motor oil, gaining hydraulic oil... #1
jeepking1
Independence, MO
Kioti DK55
New to forum, and this my first post. My girlfriends dad has a Kioti DK55, and he has noticed that he is losing engine oil, and gaining transmission/hydraulic oil.
There are no external leaks, and the engine doesn't smoke. The exhaust is clean and not blowing oil residue. He has a loader on the front with a bale spear, and a bale spear on the back. This tractor gets used mainly for moving round bales.
He has not pulled the clutch housing drain bolt yet, but the clutch seems to be working fine, so we dont think the oil is travelling through that area. We have been racking our brains and can't think of any way that motor oil could get transferred into the transmission area.
My only thought was that maybe somehow, an engine gear driven hydraulic pump might be sucking motor oil past a seal and mixing it into the hydraulic oil side?
Any help or ideas would be greatly appreciated.
Thanks, JP
   / DK55 losing motor oil, gaining hydraulic oil... #2
:welcome:
   / DK55 losing motor oil, gaining hydraulic oil... #3
Has to be a leak between pump and engine
   / DK55 losing motor oil, gaining hydraulic oil... #4
Have you tried a search through this forum yet? I seem to remember a DK55 with similar issues.
I haven't had much time to research yet, but I did find one that was making motor oil instead of losing it.
   / DK55 losing motor oil, gaining hydraulic oil... #6
Losing motor oil, gaining hydraulic oil, most of the time it's the other way around. I guess it could happen because of the hyd. pump, the seal isn't to hard to change and a good place to start.
It's a head scratcher for sure. We can't think of any other place where that kind of fluid transfer could happen.
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
KUBOTA SVL97-2 SKID STEER (A51246)
KUBOTA SVL97-2...
2007 FELLA SM350 3 PT DISC MOWER (A53472)
2007 FELLA SM350 3...
49" X 79" EXPANDED METAL RAMP GATE (A51247)
49" X 79" EXPANDED...
2017 CATERPILLAR 12M3 MOTORGRADER (A51246)
2017 CATERPILLAR...
