DK55 hydrolic QDs
/ DK55 hydrolic QDs #1
psj12
Platinum Member
Short OK
KIOTI 551
I recently tried to hook up my bucket grapple to the rear hydraulic quick disconnects of my brand new DK55. When I did they leaked. Not a drop or two, but a steady drool.
I attempted to remove them and replace them with aftermarket ones of the same type (Pioneer). I could not remove them because they were too tight and the wrenches I had were too thick so I couldn't get the required two wrenches on the fittings. After examining the after market QDs I noticed the O rings were installed differently on the Kioti. The O ring was behind the nylon ring on the Kioti but was opposite in both makes of aftermarket QDs. I removed the rubber rings from the Kioti and put them on the other side of the nylon one and the leaking was stopped. I repaired all four of the QDs on the kioti and the problems were fixed.
This is the only issue I have had with the tractor so far. I am pleased with it.
/ DK55 hydrolic QDs #2
You'll want to buy Stucchi and not Pioneer couplers, I had some lines made up recently so I could run a skidsteer post hole auger off my rear ports and the Stucchi couplers never leaked a drop.
Jason
New Quick Attach Hay Spear (A65563)
New Quick Attach...
2012 Jeep Compass SUV (A64194)
2012 Jeep Compass...
USA KB057-48" HYD BRUSH CUTTER (A65053)
USA KB057-48" HYD...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
2021 CATERPILLAR 306CR EXCAVATOR (A65053)
2021 CATERPILLAR...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
