DK55 hydrolic QDs
   / DK55 hydrolic QDs #1
psj12
Platinum Member
Short OK
KIOTI 551
I recently tried to hook up my bucket grapple to the rear hydraulic quick disconnects of my brand new DK55. When I did they leaked. Not a drop or two, but a steady drool.
I attempted to remove them and replace them with aftermarket ones of the same type (Pioneer). I could not remove them because they were too tight and the wrenches I had were too thick so I couldn't get the required two wrenches on the fittings. After examining the after market QDs I noticed the O rings were installed differently on the Kioti. The O ring was behind the nylon ring on the Kioti but was opposite in both makes of aftermarket QDs. I removed the rubber rings from the Kioti and put them on the other side of the nylon one and the leaking was stopped. I repaired all four of the QDs on the kioti and the problems were fixed.
This is the only issue I have had with the tractor so far. I am pleased with it.
   / DK55 hydrolic QDs #2
You'll want to buy Stucchi and not Pioneer couplers, I had some lines made up recently so I could run a skidsteer post hole auger off my rear ports and the Stucchi couplers never leaked a drop.
Jason
JOHN DEERE CP690 LOT NUMBER 73 (A53084)
JOHN DEERE CP690...
2015 FORD F-550 SUPER DUTY XL (A52472)
2015 FORD F-550...
2022 CATERPILLAR 259D3 SKID STEER (A51246)
2022 CATERPILLAR...
RHINO SE8A SHREDDER (A52472)
RHINO SE8A...
2018 Gatormade 20+5 Gooseneck Trailer (A52748)
2018 Gatormade...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A52748)
Kubota SVL65-2...
