DK50SE Rear remote flow
   / DK50SE Rear remote flow #11
I believe it says it is a tandem pump, so it must be that part of the pump is for the implements, and therefore all the valves should be able to handle the flow from the pump.
I was thinking part of the pump produces 6 gpm which is used for power steering etc, and the other part of the tandem pump produces the other 10 gpm which is used for implements, at least that is what people on here have told me. The implement hydraulic ports don't have the full 16.8gpm
   / DK50SE Rear remote flow #13
Your are correct. 6.8 GPM goes through steering system, oil cooler, back to mainfold to engage PTO & FWD clutches then is used for HST charge, on a SST it goes to tank. 10 GPM goes to loader, rear remotes, then 3 PT before going to tank.
   / DK50SE Rear remote flow #14
There is a kit for the DK series that allows the return line to flow directly into the fill fitting,(where the red vent plug usually is installed). A smaller different vent then is attached to the left rear housing of the tractor. This allows for running a hoe to perform at its best flow and cooler, due to not having to run through a smaller port if hooked up 'conventionally'. It is really easy to install IF one's tractor has the port in place for the newer vent fitting.
Check it with your selling dealer- I'd say most DK series since about '08 are capable of this upgrade.
BTW, Kioti's KB-2485 hoe is designed to dig to +/- 8', for reference.
I've searched and can't find this kit. do you have any links or parts numbers?
   / DK50SE Rear remote flow #15
All it is a bunch of adapters that connect to the fill pipe to a quick connect output.
   / DK50SE Rear remote flow #16
Thank you. That answered so many questions
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
2013 John Deere 650K Crawler Tractor Dozer (A53421)
2013 John Deere...
2015 Kia Sportage SUV (A55853)
2015 Kia Sportage...
40" WIDE STAIRCASE W/ METAL RAILING (A54757)
40" WIDE STAIRCASE...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
