DK50SE HST No Ballast Lifting
   / DK50SE HST No Ballast Lifting #21
I move 4x5 hay bales without ballast on my driveway fairly often. I've got to go down a 30' steeper section to drop the bale off near the feeder, so all I do is slide the bale on the ground for that part. You can do this with the bucket as well for short distances too.
   / DK50SE HST No Ballast Lifting #22
I don't have a DK50SE Cab (unfortunately, as it's a great tractor...ran one briefly a while back), but I did a pretty controlled experiment along these lines somewhat unintentionally. The steel block that I sourced from the local scrap yard to make into my counterweight weighed exactly 1,300lbs. We transported it home in my neighbor's dump truck, and I drove my tractor with FEL and forks over to his place to weld the block into a counterweight. We had dumped the block of steel onto some sections of 4x4, and I was able to just barely lift it with the FEL without lifting the rear tires (level concrete). I didn't have anything on the 3pt because I was going to be driving back with the counterweight on my tractor. Also, my rear tires aren't loaded. My loader is rated at lifting 2,638lbs to max height (at the pins). The rear tires were pretty darned light, and an abrupt move on the FEL control, or the HST control would cause the tires to raise.
So, with all that, I'd say probably something in the ballpark of half the listed max lift would be doable on a flat, level surface if you're careful.
   / DK50SE HST No Ballast Lifting #23
I do have the rears loaded which must help a bit. I also unloaded my 1000-1200lb box blade with no ballast off my trailer on level ground. I could back up in 2wd but I wouldn't lift anything with my bucket that high on uneven ground, without the box blade on the back. Half of max lift does sound about right for level ground.
   / DK50SE HST No Ballast Lifting #24
Imagine a tractor with a very heavy implement on the 3PT. The balance/pivot point would be the rear axle. Imagine that 3pt weight was so heavy the front wheels were actually off the ground. Now, add some weight to the FEL and the front wheels will again touch the ground but they will not exert the same pressure on the front wheels/axle as they would if there was no massive weight on the back of the tractor. Weight on the 3PT or at least behind the rear axle will take pressure off the front axle when lifting the FEL. I agree loaded rear tires would not take weight off the front axle even though they would stabilize the tractor but weight behind the rear axle would remove weight from the front axle by pivoting over the rear axle.
Until you lifted enough weight to lift the rear tires and your ballast off the ground then all the pressure is again on the front axle. all your ballast does is keep the rear on the ground. I do agree if you were to hang 3000lbs off the rear THEN it would be unloading the front but heck you could be riding wheelies around with that much weight!! Anyway I have 1100lbs on my three point and loaded tires, I can still lift the rear off the ground with the rollback but it seems to be just about right. 1500 would be better but I still need to haul this thing and my 1/2 ton fusses already!! CJ
   / DK50SE HST No Ballast Lifting #25
I don't believe it is all or nothing with regard to 3pt ballast taking pressure off the front axle. Any weight behind the rear axle would contribute to taking pressure off the front. Some engineer or physics wonk could do the relevant force vector sums but I cannot see how the pressure on the front axle would go from negative (big weight on 3pt that almost or barely does lift the front end) to carrying the entire 1000 lb load you pick up with that same tractor. Imagine for example that the rear ballast was enough to barely raise the front wheels. Now add another 500lbs to the rear...front wheels now in the air. Next add 1000lbs to FEL. Is the pressure on the front axle now 1000 or 500 lbs? I would say 500lbs which means the rear axle is taking some of that 1000lb load.
   / DK50SE HST No Ballast Lifting #26
If 3,000lbs would take weight off the front axle, 1,000lbs would as well, just to a lesser extent. When we put weight on the 3pt, it turns the machine into a teter-toter, with the rear axle as the hinge point. Any weight on one end removes weight from the other end....it has to.
   / DK50SE HST No Ballast Lifting #27
That does act as a ballast for stability and it does help keep the rear tires on the ground, but it doesn't do anything to reduce wear in the front axle components, for that you need the weight behind the rear axle. Safety-wise for any tractor I'd say you're right on the money at "half of max for level ground", but to prolong the life of my hardware I try to keep as much on the 3 point as I'll be working with on the front (even with my loaded rears).
   / DK50SE HST No Ballast Lifting #28
Let me try to explain it this way. I can lift the back end up with over 1200lbs of weight on the 3 point. I am guessing 1400 would be an equalizing point. That means I would have to hang 1500+ pounds off the back to even start removing weight off the front axle and I am guessing about a 4 to 1 ratio between the rear axle and weight center point to the rear axle and front center point at best, probably 6 to 1 without measuring so to take off 1000lbs off the front axle I would need 5400lbs. That is not going to happen. I'll use it for what it was designed for and it has been great for the first 350 hours. CJ
   / DK50SE HST No Ballast Lifting #29
If you can unload [lift] the rear tires off the ground your teter toter point IS the FRONT axle right? So ALL the weight is on the FRONT axle including the weight you added. Now the only time you can remove weight off the fron axle IS when the rear stays on the ground. Like the post obove says that IS alot of weight. CJ
   / DK50SE HST No Ballast Lifting #30
I still don't see it your way. Consider another similar situation where maintaining appropriate balance in weight carried by front and rear axles is important. When towing a trailer, tongue weight is important. Why? Because too much weight on the rear hitch will unload the front axle and make for squirrelly handling. So even 1000lbs of tongue weight is too much for most vehicles. However, if you move that 1000 or even 2000 lbs to a point directly over the rear axle, as with a 5th wheel or gooseneck hitch, suddenly "tongue" weight is a non issue. The front end balance is not changed whether the trailer is attached or not to a gooseneck.
2017 BX2680 Sub Compact Utility Tractor (A56435)
2017 BX2680 Sub...
2012 DODGE RAM 5500 FLATBED (A58214)
2012 DODGE RAM...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
2020 DRAGON ESP...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
2015 Freightliner Derrick Digger Truck (A55973)
2015 Freightliner...
