Dk50se front axle losing oil
   / Dk50se front axle losing oil #1
blucoondawg
Pelican Lake, WI
Kioti DK50SE w/ loader and Woods 90x backhoe, Allis Chalmers C with front snowplow
I have about 10 hours on my 400hr service over probably 3 weeks time, so obviously haven't been working the tractor too hard recently, but Sunday I went to plow my food plot and before I left noticed the front axle was out of the sight glass, haven't been able to see a wet spot to indicate the leak, has anyone had the axle lose oil? Where are the common points of failure? It's not losing it overly fast, I filled it and worked it a few hours and it's still fine, and I looked at it about 5 hours after the service and it was still in range in the sight glass so it took a few weeks to get down there and mostly sitting not working.
   / Dk50se front axle losing oil #2
On mine i had a front seal go bad. Did not notice leak until i removed front wheels.
   / Dk50se front axle losing oil #3
Did you keep close track on the amount you added on the refill. My white version of that series had a hard time getting all the fluid back in that I took out. I had to let it settle for a couple days and then top it off again.
I did not I was kinda in a hurry to get my work done, the ball on the sight glass was all the way down, like it was completely empty though I'm sure it was not as it did not take as much as it would had I drained and refilled.
It does seem to take a little while to drain all the way into the axle, it seems it took maybe 4 quarts, filled my funnel twice and then most of another one and it's a 1.5qt funnel
   / Dk50se front axle losing oil #5
My dk45 takes 1.98 gallons in front axle. 7.5 L. I end up draining mine using compressed air thru filter. Hard to get it all out.
Ya I know, it wasn't completely empty though it was completely out of the sight glass
   / Dk50se front axle losing oil #7
The site glass does not indicate empty. When the axle is at least 1/2 full my site glass shows empty. It only indicates safe operating range is my thought.
   / Dk50se front axle losing oil #8
Same here. Just add and keep an eye on levels going forward. You may be fine.
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
2018 New Holland T8.350 MFWD Tractor (A53342)
2018 New Holland...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A53472)
2023 NEW HOLLAND...
